Hello, I have an OKI C3400 printer and all the lights are blinking and I got an error message on the server saying "fatal error." I've turned it off, then back on, re-setting all the drums and it started back up as if it were going to work (just the one green ready light) but it didn't print. So, I turned it off and back on again, and it's back to the fatal error blinking lights. Also, when I type in the IP address into a web browser box, the info page that normally comes up does not come up. I just get an error pop-up.
both the paper/ink buttons blinking in red simultaneously means fatal error. Use AP for figure the latest fatal error code. Btw, i have Service manual for 1400. Contact me at aicaxz(at)yahoo(dot)com
epson R230 2 red light start Printer status Fatal ERROR LED indicator power: OFFpaper: FAST BlinkInk: FAST Blink Carriage Unit cannot move correctlyMotor cannot rotate correctly Note: CDR (CD/DVD) guide assembly is not close properly will also occurs error or blinking the paper indicator and ink indicator. For easy to me to understand.Please check the light indicator, either blinking simultaneously?
Error status (Amber, blinking): you cannot continue to use the printer. Intervention is required to recover from the error. Fatal errors are irrecoverable and require a service call.
Blinking 1 (2S cycle) An error has occurred but printing can continue if you press the ON LINE or CANCEL switch.
Blinking 2 (500mS cycle) An error has occurred. You need to replace consumables or remove jammed paper, for example. The printer then recovers from the error and printing becomes possible again.
Blinking 3 (120mS cycle) A serious error has occurred. rebooting or a service call is required.
The Status Monitor in Windows provides a readable description of the printer status corresponding to the indications of the LEDs. In Mac, the printer driver provides status information once you have sent a document to print. In Windows, if you have the Status Monitor Preferences set to Pop up on alerts, this readable message will be presented on screen whenever an abnormal condition occurs.
If all the leds are fast blinking, you have a fatal error.
Most likely something has been overlooked during re assembly (forgotten connector maybe ?) as there is no need to reset the fuser.
Run Status Monitor and make sure it is really a paper jum that prevents printer from printing. It is very likely that another reason is in place. For instance - toner empty of change drum request. All of this causes the "Attention" LED to blink: it's not only paper jam that causes it.
When the alarm light is blinking what other lights are on. This is the fatal error code with the printer.
Remove the ribbon. if still not moving smoothly unit needs service. 3 year warranty on this unit brand new.
If you cannot move the carriage back and fourth accross,
