SOURCE: I have a side by side Hotpoint model
sounds like the water inlet valve is not letting the water come in. need to check and perhaps replace this valve. hope this helps.
SOURCE: Hotpoint side by side (Model HSS251FMD)
more than likely no the baffel door that opens when the call for ice is performed is more than likely sticking open due to the possibilty of beverage sloshing up and around the piviot points
SOURCE: HSS251FMD WW refrigerator evaporator motor will
check voltage to the fan if you get voltage then the fan is bad.
contact me at www.911servicetoday.com
SOURCE: Flapper in ice chute remains in open position.
Solved via another post. Appears that the solenoid that moves the flap needs to be replaced. Already ordered the replacement. It's easy to remove the plastic facing without removing the entire trim around the chute opening. About one inch in at the inside top of the chute area there are three small holes. Starting with the leftmost hole, use a small phillips screwdriver to push up while using the other hand to pull out on the left side of the plastic part that houses the water/ice selection buttons. Then do the center one, followed by the rightmost one. That exposes the inside plastic housing which is removed by taking out the four screws. Its easy to get to the solenoid that has to replaced - unclip the wiring and remove three screws. Then reverse the process.
SOURCE: My Hotpoint Side by side HSS251FMD WW works for a
Yes is sounds like it is getting stuck in defrost. This happens often. You will need a new timer.
I hope this helps.
