Sony Ericsson W910i Cellular Phone Logo
Anonymous Posted on Mar 25, 2009
How to put new fascias on w910i helllllllllllllp
Hi, i need to find a way to remove and put a new fasias on my w910i, hellllllllllllllllllllllllllllllllppppppppppppppppppppppppppp
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Sep 09, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
671
Points
5
  1. Turn off the phone.
  2. Remove the 4 screw covers on the back of the phone, 2 on the top of the main body and 2 at the top of the slider.
  3. Take out the 2 screws at the top of the main body.
  4. There is a 3rd screw on the right hand side of the phone above battery pack, take this out. dont forget where each screw came from.
  5. you can now remove the back plate.
  6. next you will need to remove the 2 screws on the top of the slider.
  7. Remove the battery pack.
  8. (make sure the slider is OPEN) You will see two screws on either side of where the battery pack was. Remove these.
  9. You can now Remove the front plate.
Bassically uncrew all the screws. take it apart, put your new stuff on and then do everything again backwards.
3answers
Where is the windsheild washer pump on a 2002chrysler Cirrus
It's attached to the windshield washer tank
Removal of fasia on mieie w970 wasing machine to fit new on off switch.disp removed and 3 screws removed .right hand side is fixed dont want to force it.
Hi dear. Open the door. There should be 1 or 3 10mm bolts around door gasket remove them. Where soap dispenser Top LHS 3 T10 screws,remove them. Open Bottom LHS pin trap.Remove the drain hose from the cover and right underneath it, there is a clip. You need to push it down to open front panel from left to right. Then you can access it. Thanks.
1helpful
How do I replace rear parking sensor
You have to take bumper cover off .
Remove rear bumper fascia. Refer to Rear Bumper Fascia Replacement . Disconnect electrical from the rear object sensor. Lift the locking tabs on the housing and remove the rear object sensor.
Preliminary Procedure
  1. Remove the compartment sill plate. Refer to Rear Compartment Sill Trim Plate Replacement .
  2. Remove rear wheel liners. Refer to Rear Wheelhouse Panel Liner Replacement .
Rear Fascia Push Pin Retainers (Qty: 2)
Rear Fascia Nuts (Qty: 4)
Tighten
10 N?·m (89 lb in)
Rear Fascia Bolts (Qty: 2)
Rear Fascia Bolts (Qty: 6)
5
Rear Fascia
Tip
Energy absorber and fascia are removed together. Cannot be separate on vehicle.
Disconnect the electrical connectors.
How do u change a fascia on the Sony Ericsson W910i?
you change original cover sony ericsion is not set in cover
3helpful
2answers
I want to unlock my sony ericsson w910i fre how
hi friend,
press * and then press the right soft button to unlock if it doesn't works check this out Unlocking your Sony ERICSSON W910i is just the start of roaming freedom. This safe, simple process is one of the easiest ways you'll ever find to save money. The unlocking code and five minutes of your time will enable you to use your handset in ways you never thought possible.
We need only a short time (no more than 12 - 24 hours ) to generate your Sony ERICSSON W910i subsidy code. The sooner you place your order, the quicker you'll receive the unlocking code and be on your way. Both ordering and entering the code are easy. Just follow the instructions.
How It Works
  1. Select your phone and fill out our order form
  2. We will email your unlock code along with easy to understand instructions on how to enter it.
  3. Put in a different SIM card and enjoy your new freedom.
Once you have received your Sony ERICSSON W910i unlocking code, it is very simple to enter it:
  1. Remove the SIM card. Turn your handset ON
  2. PRESS the left arrow ONE TIME
  3. PRESS the * button TWO TIMES
  4. PRESS the left arrow ONE TIME
  5. The message "Personalize with MNC2" will appear
  6. You may now enter the Unlocking Code we sent to you. It may be necessary to PRESS ENTER or OK
    ERICSSON
    -W910i-,K850i-&-W890i-UNLOCK_...%20-">cgi.ebay.co.uk/UNLOCKING-FOR-SONY-ERICSSON-W910i-,K850i-&-W890i-UNLOCK_... -
hope this helps u
thank u for using fixya
please rate me............................
regards
sivaranjini
How to change the housing ?
Heres the first part...
http://forums.se-nse.net/lofiversion/index.php/t40398.html
for the bottom half, you just remove the 2 screws at the top, then if you remove the little plastic bit just under the bottom keypad there are a further 2 screws remove those and the back part can be taken apart quite easily :)
4helpful
2answers
I need to remove front and back fascias of my 6500 classic
I had the same problem. Watch this video for full instructions.
http://uk.youtube.com/watch?v=wmtOn3KhcQI
Contacts issue
you need to take the phone and have the firmware reflash on the phone to correct this issue....or try online at topsony.com.
2helpful
3answers
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
