Dell E151FP 15" Flat Panel LCD Monitor Logo
Posted on Mar 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E173FP monitor fix
Did you ever get the monitor fixed ? My monitor is doing the same thing (blank screen, power light blinking green and will not shut off) i have a dell monitor e151fpb and the led power light keeps blinking green,the screen is just black, i tryed the video test but nothing seems to appear on the screen,i plugged the hard drive into another monitor and it works completely fine. this dell monitor is a replacement monitor after the first one was damaged. do you think dell will be able to replace it?
Mark Gough
Level 3:
President:
  • Master 415 Answers
  • Posted on Mar 25, 2009
Mark Gough
Master
Level 3:
President:
Answers
415
Questions
Helped
156812
Points
1679
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
I have a blank Dell E173FP monitor with the green blinking light. I have ordered and received the repair/replacement parts. Can someone please respond with detail instructions to fix the problem? Thank...
yumaparkie, You mean to tell me you haven't been to YOUTUBE to see all the video clips of Dell E172FP, E173FP lcd monitors being repaired?? Do that first, then come back here if you still need help.
12fixlouie
2helpful
My Dell E173FP monitor will not come on. I have unplugged and replugged the cable from monitor to hard drive case as well as the a/c power cord. I have rebooted the computer several times and all I get on...
The dreaded blinking green led without a display, means that the backlight circuit has failed on this monitor. Typicalll the transistors that drive the backlight transformers short out and fail. I have fixed this on my monitors twice. Very common failure for this monitor and can be fixed quite easy if you know how to use a soldering iron and a meter. They even sell a repair kit on ebay that provides parts to repair this monitor. Just go to ebay and search e17fpb repair and to find it. Hope this helps.
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
3helpful
Dell monitor shows blank screen, green power light stays on
You have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the bad parts,replace any that look like the pictues and your monitor should workfine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one thesame way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
2answers
Monitor is Blank and Power Light Blinks
JH77,
Hi...Ya! It's seems your LCD monitor backlight inverter just run out of lucks... it's burnt out. Need to replaced a new inverter. Have a nice day!
Final Answer to Dell E173FP blank screen problem?
Check out this link http://www.lcdrepair.us/Installation.html
They have help videos on that model and sell repair kits as well as the whole board.
3answers
Blinking green power on
1. remove your RAM and clean it and re fix it on motherboard if its just that problem it may come up.
2. try other RAM from any working PC to ensure your RAM is serviceable.
5answers
E173FP monitor fix
Well, here's Dell's answer:
http://support.dell.com/support/edocs/monitors/E173FP/En/trouble.htm
Monitor went black
Same with mine a couple days ago. I've been told the contacts have oxidized and need to be cleaned. It was going to cost about $80 to fix and no guarantee how long it would last so I just bought a new monitor.
2answers
Flickering switch light, blank screen
Hi, First of all it is not advisable to open up monitors without proper tools as they contain hazardous elements. Dell monitors however do have a 3 year SEPARATE warranty. Check on the back of the monitor and look for the monitor serial number. is should start with CN-xxxxx-,, or JP-XXXXX-. give that to a dell tech and they should be able to replace that.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
