SOURCE: aerus lux 5500
There is a red button on the head of your power nozzle. It is the reset button. Try hitting it and see if that helps.
SOURCE: kenmore vacuum model 37105 no suction
are the brushes moving?if so , it is clogged somewhere, that is my guess
SOURCE: Cannot fill gas tank on 2002 Kia sedona. Even when
I have a Kia Sedona 2005 and I can't fill it up with gas without the pump kicking off and I have tried several gas stations. Sometimes I can get a few gallons in with no problem but then it kicks off again and I have to spend twenty minutes dripping fuel into it until I loose patience. Help me!
SOURCE: Dyson stowaway hose seems clogged..
Sorry to hear you're having a problem with your Dyson. You should find the issue easy to resolve - please visit the Support section of our website and follow these simple steps to make sure everything is correct with your machine:
http://www.dyson.com/support/help.asp?article=1009&product=DC21-MOTORHEAD_US
It's also a good idea to wash your filters, which should be done every 3-6 months. You can see a video guide demonstrating how to do this here:
http://www.dyson.com/support/help.asp?article=1011&product=DC21-MOTORHEAD_US
If you've tried these steps and are still having difficulties, please get in touch with us free, on 08002980298 (UK), or 1866MYDYSON (US), so we can run through some checks over the phone.
Kind regards,
Jack
Dyson Customer Service
SOURCE: My Bosch shu3307uc pumps out all the water at the
Hello, welcome to FixYa.
Based on your post I understand you have a Bosch SHU3307UC dishwasher, correct ? Firther to this you.ve stated "slowly fills the bottom between cycles, even with little or no activity at the sink"
It sounds to me like the fill valve is at fault unfortunately. This is a very common problem for Bosch dishwashers of that era.
A faulty fill valve...sticking in the "open" position either due to the plunger in the coil getting stuck or sediment inside the valve body impeding it from closing correctly...Either way you're safer to change it with the history of these valves failing.
This is what to look for...
As long as your model is indeed a Bosch, this info below will be accurate.
Original part is # 425458. It usually retails for about $20 - $30USD at places such as "searspartsdirect.com" "repairclinic.com" to name a couple, if needed. They may be available at your local brick & mortar parts depot/vendors.
**Before attempting to repair the unit please turn off the power and the water supply to the dishwasher...safety first**
If you remove the lower kick plate/toe panel, you will see the inlet valve to your left...
i.e.
Replacing it or to check for debris in the filter/screen at the inlet is pretty straight forward. Here`s how...
1) undo the water line. ( here you can visually inspect the screen in the valve...if nothing noted, you'll likely need to replace it as follows )
2) Remove the two #20 torx screws fastening it in place.
3) the feed tube to the machine at the back of the valve and swap it with the new one.
and
Once the new one is in or it's all clear you should be good to go.
Let me know if you need any further assistance. Thanks for choosing FixYa and good luck.
Please take a moment to rate the assistance provided here and a brief testimony on your experience here at FixYa is appreciated as well and tell your friends to look for "Macmarkus" on FixYa should they need asistance as well.
Regards,
Macmarkus :)
Testimonial: "The fix was easy and exactly as described, and works perfectly! Thank you very much! If you need any car advice, look me up, I will be glad to help! Bob"
Most likely is a bad EVAP purge valve. But check below list.
This indicates that a part of the EVAP
control system is no longer functioning correctly. The EVAP system consists of
many parts, including (but not limited to) the gas cap, fuel lines, carbon
canister, purge valve, and other hoses. The (EVAP) emission control system
prevents the escape of fuel vapors from a vehicle's fuel
system. Fuel vapors are routed by hoses to a charcoal canister for storage.
Later, when the engine is running a purge control valve opens allowing intake
vacuum to siphon the fuel vapors into the engine.
EVAP emission canister purge is controlled
by a valve which allows engine vacuum to pull stored fuel vapors from fuel tank
into the engine to be burned, rather than be vented to atmosphere. A vacuum
switch is used to detect when flow exists. If the PCM commands purge and sees
that the switch is closed (indicating no detected purge flow) P0441 is set.
FB.init("dd7d9e9681341cde77587bc6a2029f6f");
OBD-Codes.com on Facebook
Symptoms
Likely, no symptoms will be discernible to
the driver, other than the illuminated Check Engine Light.
Causes
A code P0441 could mean one or more of the
following has happened:
With a P0441 OBD-II trouble code, diagnosis
can be tricky at times. Here are some things to try:
