Cars & Trucks Logo
Jeff Andries Posted on Jun 24, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to replace a 2' x 6" section of my balcony
Irene Betzold
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 56 Answers
  • Posted on Jun 24, 2013
Irene Betzold
Expert
Level 2:
New Friend:
Greenhorn:
Answers
56
Questions
Helped
6255
Points
148
Replace the whole board, there is also a product woodlike filler that works even in the rain. will set up harder than original wood, ask at home depo, you want to stop rotting as it quicly spreads
1 Related Answer
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jul 18, 2012
SOURCE: floor board on 1999 GTI rotted out on passagers side in back
Hello
Fixya has no parts resources so I can't suggest the source for this part. I will tell you that you can't just buy a floor board, so you will need to patch it with sheet aluminum and a pop rivet gun.
1helpful
2004 Colorado pickup frame rotted
Find you a professional welder, like the rot Iron fence installers and have them weld flat iron the entire length and it will last longer than the rest of the car.
2answers
04 cadillac dts roof leaking and floors getting wet. Pretty sure it's the sunroof drain. Where are they?
Under your headliner, than routed outside the car through your a,b and c Pillars
1helpful
Floor board on 1999 GTI rotted out on passagers side in back
Hello
2answers
What is the P0440 trouble code on a 97 850 volvo non turbo
Code is for the evap system which vents gas fumes from the tank.
Could be anything from a bad gas cap to a leak in the vent system.
2helpful
2answers
My 1995 deville codes tell me I need a new MAP. Where is it located on my 4.9 engine?
I think these pictures should help. Hope it does. Make sure the vacuum line that goes to it is not real loose, dry rotted or leaking in anyway. This will pop a code as well. Good luck....
MY BRAKE PEDAL IS HARD TO PUSH DOWN AND A SMALL HOSE CAME LOOSE THAT IS CLOSE TO THE FRONT WINDOW IT LOOKS LIKE IT'S AN ELECTRIAL BOX
That may be whats known as a manifold vacuum line. It supplies suction to the brake booster which makes braking effortless when the pedal is pushed. They have a tendency to dry rot and break on their own from age and can be easily replaced. Most auto parts stores carry them in their help section.
2answers
2002 Dodge Neon, approx 99,000 miles, engine light came on, error code PO605 & another error code related to transmission, auto transmission - driving anything over 25 mph won't "kick up"...
Its the TCM- Replace the Transmission Control Module. WITH THE DRBIII PERFORM QUICK LEARN AND REPROGRAM PINION FACTOR.
The transmission Control Module (TCM) is located behind the passenger fender and is fastened to the frame rail forward of the suspension. Here is a picture of it...
How to apply the hair colors
it depends on what brand you are using, most of them mix1:1 with the corresponding developer however some mix 1:2 depends on if it's semi, demi, or permanent color, should say in the directions. section hair into a quad parting, go from middle of nose to nape and then from just behind each ear across top of head to other ear and you have your partings. do one at a time i suggest starting in the front section a horizontal piece about 1/4" thick and apply color to the middle of the hair, 1" from rots and 2" from ends, do this in each section then go back and apply to roots all over head then go back and do ends total of 3 times in each section. process for 20-30 mins, good luck.
AUTO TRANS OILCOOLER HOSE
Do u need to replace a damaged or rotted section of trans. coolant line? If that is what u are asking, just purchase a section of rubber gas line and hose clamps, cut out the damaged section, install hose and clamps. Works great.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
