Question about Panasonic KX-T7433B Corded Phone
How do I store numbers on the phone system.
I've tried following the instructions in the manual and they don't work.
Posted by jane603 on
  • jane603 Mar 25, 2009
    I was following the instructions in the manual on storing numbers i.e. Program, **, User Password (which I think is 000) but I can't even get as far as the User Password.
  • Carl Navarro
    Carl Navarro May 11, 2010
    What instructions are those? What buttons do ou press?
Carl Navarro
  • Panasonic Master
  • 2,460 Answers
From the phone connected to Jack 01 (probably ext 101) press PROG **1234 001. Then press SP PHONE and you should be looking at speed call bin #001.
SP PHONE steps you through the numbers and all numbers you add need to include the trunk access code, be it "9" or "8x" before the number. STORE saves it.
Carl
Posted on Mar 25, 2009
I need the puk for huawei HB4J1H
PUK codes are only available from your service provider
call them on another phone, provide proof that you own the account and they will give it to you
If your service provider goesn't have a 24/7 service number , change service provider to one that does have
Jan 12, 2018 | Cell Phones
Lost directions on uniden cordless phone DXAI8580-2, unable to access message as code using does not work????
If you mean the PIN for remote access, that's a two-digit number. If you've forgotten what it is, you can change it at the base station by following the instructions on page 12 of the manual.
If you mean the messages on your telephone company's voicemail system, try dialing *67 (that's star-six-seven). If that doesn't work, contact your telephone company for instructions on accessing their voicemail system.
Jul 10, 2012 | Lands Phones
Need user manual huawei m615
i dont think user manual is provided extra...
otherwise please comment below and rate my answer 5star ..telll me your problem or anything you wanna know about it and i'll help
Dec 01, 2011 | Cell Phones
I've lost the instruction manual for my samsung GS 3650
you just follow this links
http://www.samsung.com/my/support/search/supportSearchModelResult.do?menu=SP01&searchWord=corby2&default_searchInputBox_value=Enter+model+number+or+keywords&searchInputBox=corby+2
Nov 01, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
I've tried to follow instructions on Pg.9 but when the display has the following Delete Entry, there's not button to push or Arrow, I press Clear (for Delete) and nothing happens. It is very...
If you just want to dial a number in the phonebook, press up/down to find the entry you want then press TALK/FLASH. Look at page 10 in the manual, under "Using the Phonebook".
Aug 26, 2011 | Uniden DECT1363BK Cordless Phone
My iPhone is blocked i can`t see my home screen and the only thing that comes it the Usb showing connect to iTunes and nothing else ,i have tried all the ways to restore but still the same,can give you my...
If you've followed it's instruction to connect it to iTunes and done a sync and nothings still working on it. then it's a problem with the phone. You could try updating the firmware to a newer version and seeing if that helps.
A lot of times, restoring from a previous sync is the harm done. Sometimes, I don't know why. But an old file can corrupt and make things really hard
Aug 16, 2011 | Apple iPhone Smartphone
We've lost the instruction manual for our light switch timer so don't know how to reprogram it. Directions, please!! We've just replaced the battery.What buttons do we press in what order to...
Question posted under Intermatic timer:
Open following link to identify timer and download possible manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
IF Intermatic timer stopped working because battery failed, then all that's needed is to reprogram current time, because the original timer programs you set are stored inside timer forever until timer is manually reset using reset button.
If you have Intermatic ST01C timer, then open following page for ez instructions:
http://waterheatertimer.org/ST01C-program.html
If you need help programming specific timer, then get as far along in manual as possible, and then add a comment.
If you have different brand timer, than each brand has link that shows on Intermatic page.
Aug 10, 2011 | Intermatic Hardware & Accessories
How to install phone no. in ET 3576 to memory
I think most Radio Shack phones work pretty much the same. They don't have a manual available for yours so I'm not absolutely sure, but I've had a couple of their phones. To store a number in those, it was just three steps:
  1. Press MEM
  2. Enter the number to dial
  3. Press MEM again, followed by the location button (on phones with single buttons for emergency numbers) or the memory location (one or two digits depending on the number of memory locations)
Try these steps and see if it works for your model.
Aug 03, 2011 | Lands Phones
Hi I have a panasonic KX-T433 phone system which I am trying to put in speed dial numbers, we have to dial 9 to dial out does any one know how to do this using a 9 in front?
You have neither a 7730 (the category you asked in) or a 7433 phone sytem. If your phone is really a 7433, you have a TD phone system. Which "speed dial numbers" are you trying to program? System speed dials, are stored in system program 001 and consist of a 3 digit number (may be 2) with a "9" in front and the number as you would dial it from the keypad. Personal speed dial numbers depend on the button you're programming it onto. If it's a button with a light, you dial "2" in front of it. If not, you don't. So, Program 99, button, and either 29 + number STORE or 9+number STORE programs a personal speed dial.
There are other programs to store under the tone pad keys. Those features are covered in your User's manual for the TD system.
Carl
Jul 06, 2011 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7433B Corded Phone Logo
124 people viewed this question
Top Panasonic Lands Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Henk de Ruiter
Henk de Ruiter
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
