Creative Labs ZEN V Plus MP3 Player Logo
Question about Creative Labs ZEN V Plus MP3 Player
My creative zen plus is stuck on play but no music, no other buttons work and I cannot shut it down.
Posted by mdjohnson120 on
  • 1 more comment
  • troth181 Apr 17, 2009
    My Creative Zen is also stuck in play mode four seconds into a song. None of the buttons work, and I can't turn it off either...it is completely frozen. Anybody have any ideas???
  • Anonymous Apr 19, 2009
    The music stopped an everything stopped working except the screen which was froze and won turn off and nothing will work at all.It's like the whole thing broke but is still on.
  • lugh Apr 20, 2009
    The same thing happened to me - I was connected to the PC when it just froze, none of the buttons work.
Anonymous
ZEN V
ZEN V Plus
(DAP-FL0036)
  1. Turn off your player (if possible).
  2. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
  3. Power on the player.
  4. The reset hole for the ZEN V / V Plus is located on the left side with the player facing up.
Posted on Apr 23, 2009
Anonymous
Is there a connecter that I can buy to connect my Dell to my Apple computer, to share the printer and the new 22" X223W Acer Screen?
Posted on Mar 25, 2009
2answers
I can't open my zen v plus and it always light up and there's no start up screen
Can it still play music if you press play after it lights up?
Can you still connect it to a computer?
This sounds like a dead screen, which means it is time for a new player.
Wont turn on
you need a new battery for you zen
look on ebay.com
or do a search for creative labs zen vplus battery
on the inetrnet
3helpful
My creative zen v plus is stuck in shutting down
i think i have a different version of zen but hopefully it'll work for you. i held down the power button and pokes the reset button with a pen tip for about 5 seconds and it finially turnned off! i've had alot of problems with the zen and it sorta happens alot and most times you need to do different things but the same problem usually doesnt come bk. good luck
My zen is frozen on creative
If a reset does not work then try this: First, back up all of your music and do this: Turn off the player and disconnect it from the computer. Then press and hold the play/puse button and turn it on simultaneously. The player should be in recovery mode. Scroll down and select format (all) and let it format. Then reload all of music back onto your player and it should work like new. Hope this helps!
Omy zen v plus is stuck on the shutting down screen, it has been for about four hours
Press the "reset" button. If it didn't work, upgrade the firmware of this product. If problems still continue, contact the Creative company.
Creative Zen vplus 4gb Stuck on start up screen that says "ZEN vplus"; it will not shut down once on, unless using the reset button
see recovery mode info here:
http://www.anythingbutipod.com/forum/showthread.php?t=6714
(thank you)
holding play button while powering up, then running Clean Up & rebooting did the trick.
5helpful
2answers
My creative zen v plus is not detected by my pc when connected its screen has reddish lines neither it is shutting down nor it is working
Using the instructions below try Cleanup first, if that doesn't work... (if you have a backup of all your music on your computer), try the format option
This is from Creative's website:
Zen V Plus and Zen V
  1. Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Message Edited by Jason-CL on 09-11-2006 12:02 PM
Forum Administrator
Creative Labs
Recovery Mode
Clean Up
Format (All)
Reload OS/ Firmware
2answers
Creative Zen V 2gb Plus
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
if that didn't work try this http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
2answers
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Muzahura Frank
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
