Question about DeLonghi Pinguino PAC-02 Air Conditioner
166 Hi I would like to know my air conditioner stop every 3 hrs i have to empty the tank is that normal
Posted by manon lamarche on
Henry S
    Sergeant:
  • 301 Answers
Yes this is normal. Your a/c pulls water from the air that is blowing out. If it is real humid then you are going to get a lot of water in the tank
Posted on Jun 24, 2013
With code Ft at delonghi pac c100
Ft = normally means empty the internal tank, this is normally done at end of season cleaning storage. On some units there is a small ''bung'' low on the rear which will empty the tank - the unit should then reset when powered up. Hope this helps
Jan 24, 2011 | DeLonghi PAC C100 Air Conditioner
It starts an stops an will trip the cir
The compressor is going bad...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 05, 2010 | Dometic Rooftop RV Air Conditioner
The water tank has to be enty every1 1/2 hrs
Must be very humid where you are. I have to empty the tank about twice a day and I find this a real pain since the plug is in the back of the unit...
One thing I was going to try is to buy a few feet of 5/8" hose, this is internal diameter. I don't a drain to send it to, but if I can find a clear hose, it can help figuring out the water level and make it a little easier to empty.
Not a perfect solution, I know.
Aug 30, 2010 | Royal Sovereign ARP-3012 Air Conditioner
The unit stopped blowing cold air...it has been drained and cleaned. what could it be?
heatman101
Aug 27, 2010 | Sharp CV-P09FX Air Conditioner
My portable air conditioner stopped working. It comes on with very little noice but doesn't kick into that full on state. Then it blows a little warm air.
heatman101
Aug 26, 2010 | Danby DPAC8020 Air Conditioner
My fan stops working, ac still on
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 21, 2010 | Amana Heating & Cooling
Why my ac 24000btu stop after short time
heatman101
Aug 17, 2010 | LG LSC121PMA Split System Air Conditioner
Full Tank very fast
witch model do you have, for some models thats normal on others its not, some run the water over hot coils and it evaporates others the water goes into a holding tank and sits their til the tank fills up then you must empty. expect more water when high humidity or in the summer
Jun 27, 2008 | DeLonghi Pinguino PACL90 Portable Air...
DeLonghi Pinguino PAC-02 Air Conditioner Logo
60 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Sheldon Dedek
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
