Question about AT&T DECT 6.0 Cordless Phone System with Digital Answering Machine
Base The ringer on my base is set to 'off'. It only rings on my hand device. How do I turn the ringer back on my base?
Posted by deb durre on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • AT&T Master
  • 102,366 Answers
What model AT&T DECT 6.0 phone?
Posted on Jun 24, 2013
I have an uniden exa 2980 and losy manual,how do I obtain a copy.also how do I turn up ring volumn?
Uniden has the manual for the EXAI2980 here: https://www.uniden.com/File%20Library/FooterNav/Product%20Information/Owners%20Manuals/exai2980om.pdf .
Do you need to adjust the ringer volume of the base, the handsets or both? To set the ringer volume of the base, start with the phone in standby mode (no calls being made or received) then press Menu 4 times (the right-hand button in the row above the volume up/down buttons). You should hear the current ring volume and see it displayed on the LCD screen. Press Set (the left-hand button in the row above the volume buttons). Press Skip/FF or Repeat/RR (the buttons on either side of the Play button below the LCD screen) until the desired ring volume level is displayed. Press Set to save the setting. Press Play/Stop to exit the menu system. See page 38 of the manual (page 40 of the PDF above) for the directions.
To adjust the handset ringer volume, press the handset volume up or down buttons with the phone in standby. The last chosen ringer tone and volume will be saved. See page 16 (page 18 of the PDF). Sometimes, the handset will not ring after losing the security code that pairs it to the base. Remove the handset from the base. Press and hold Page on the base (between Set and Menu). While the handset is sounding the paging tone, replace the handset in the base. Leave the handset in the base until the flashing stops (more than 5 seconds). See page 47 of the manual.
I hope this helps.
Feb 12, 2018 | Uniden Lands Phones
When answering mode is on I do not want to hear the ringing(4x) tones before going to answering.I've switched off the 'call screen' option. still I hear the ringing although not recording at least.
Just set the ringing volume to off.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings
May 29, 2015 | Uniden DECT 6.0 Cordless Phone ID
HOW DO I TURN THE RINGER ON. HAND SET READ RINGER OFF
Temporary ringer off While the handset is ringing for an outside call, you can turn the ringer off temporarily by pressing {OFF}.Adjusting the base unit ringer volume Press {^} or {V} repeatedly to select the desired volume.To turn the ringer off, press and hold {v} until the unit beeps 2 times
Sep 22, 2011 | Panasonic KX-TG5632 Phone
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
Jan 03, 2010 | Uniden DECT 6.0 Cordless Telephone...
The base ringer on my Uniden TRU9480 base station rings very loud and cannot find where to either adjust or discontinue the ringer. Jackgee1
I found my owners manual and to adjust the ringer on either the Base Station or Hand Set as follows:
with the hand set in place just use the base arrow up or down to go from 0 (off) to 2 (loud) and on the hand set just use the arrows for high low or off. Just bew sure to have the hand set on the base before adjusting the ringer
jackgee1
May 01, 2009 | Uniden 2.4 GHz Cordless Phone System
Handset won't ring
You need to reset the main base and make sure the ringer volume is turned all the way up. Disconnect the power from the back of the main base, press and hold find hs key while reconnecting power until you hear long beep. Should reset base and handset.
Mar 17, 2009 | Uniden DECT 6.0 Cordless Telephone...
Ringer off displayed on base. How do I turn it back on? Just called myself from my cell phone and phone actually did ring.
Thanks for giving me the opportunity to help with your problem.
The "ringer off' message on the base display is referring to the ringer on the "base" unit not the phone ringers. Your phone handset(s) will still ring even when the base ringer turned off.
To turn the ringer on the base back on press and hold push the ^ symbol on the base until it beeps two times, To turn the base ringer off, press and hold the v symbol until the unit beeps.
If my information has proven to be of help, please give me good rating. Thanks for using FixYa!
Jan 27, 2009 | Panasonic KX-TG5632 Phone
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
Ringer off
The VT-9118 can use one of 4 different ring tones, and can be turned off.
To reset your ring tone:
  1. Remove the handset from the base.
  2. Press PROG. You should hear a single short beep.
  3. Press #.  You should hear a single short beep.
  4. Press a number 1 through 4. You should hear a long "ring" tone (it might be startling!). You can try other numbers from 1 to 4 to hear them all.
  5. Press MEM to confirm your ring. You will hear a medium beep.
To turn the ringer off, follow the same instructions, but choose number 5.
Hope this helps you. If you need for information, you can download the user manual from http://www.vtechphones.com/docMgt/public/art/313/vt9118.pdf
Jan 17, 2008 | Vtech VT-9118 Cordless Phone
AT&T DECT 6.0 Cordless Phone System with Digital Answering Machine Logo
65 people viewed this question
Top AT&T Lands Phones Experts
Marvin
Marvin
Jax Planet
Jax Planet
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
