Hi.. im using HL-DT-ST DVD-RAM GSA-H54N driver to burn CDs & DVD'd back then.. but now i can't use it anymore... it can read CD's but cannot read DVD. it cannot also burn CD's & DVD's
open it up, with the lens
assembly there is a small preset, turn it using a screw driver a little
anti-clockwise..clean the lens with clean cotton using isopropyl
alcohol.. if not done, replace the lens assembly.. or else, replace the drive with a standby n see..
i gotta know: is ur drive pata/sata and the device make n model.. assuming that ur drive is pata, n u r a professional n aware of bios/cmos setup utility handling..!! openup
ur system cabinet and see if all the data cables n jumper settings at
the back of the drives (master/slave selection)..itz most important..!! however,
at the bootup (0.29sec) start pressing briskly the key to enter cmos
utility or bios setup (eg. F1/F2/F10/Delas applicable)..glance in the
standard settings if r detected individually..change the 'Mode' if m/b
is hybrid type(both SATA+PATA) :Native/Compatible/Enhanced (as
applicable).. see if ur device needs any additional driver or not, if so try downloading.. also try checking itz data cable for loose or faulty.. above all explanation is applicable only if itz not being detected by the m/b or system..(not for reading or writing problem)..
There is a Microsoft KB article on this subject. Here is the link : http://support.microsoft.com/kb/314060
Just follow the instructions and it may solve your problem
I Have A : HL-DT-ST- DVD-RAM GSA-H22N DVD Burner That Works Fine With (CD Burning/ Reading) & (Data Burning/ Reading) But I Have A Very WIERD Problem With The DVD : Here I Go, When I Use Any Program To Burn DVD Like Nero, DVD Shrink Etc.. (It Appears That) The Movie Is Burning Well, Because In The Burning Process It Doesn't Says Something Like:Bad Disc, Not Succefully Burned Or Any Sign That The DVD Burner Is Damaged , Also When It Finish Recording You Can See The Data Burned In The Disc By The Lines It Forms BUT !! I Don't Know WHY The Fu$%@@ , When You Test The Movie In Any DVD Player , Comp OR Whatever THE MOVIE DOESN'T WORK.
how can i do that?
