Buffalo Technology 320GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD Hard Drive Logo
Posted on Mar 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cant find Buffalo ministation in my comp after connecting it
I bought a Buffalo ministation 320gb. I connected it to my laptop with XP OS. I cannot find it in my computer to use it. Kindly help
Anonymous
Level 3:
  • Master 3,153 Answers
  • Posted on Sep 24, 2009
Anonymous
Master
Level 3:
Answers
3153
Questions
Helped
1165595
Points
11010
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Buffalo Ministation not flashing or recognized
Im having the same problem sound like your cable is not working or you need a new case because the pins are broken.
1helpful
How to format buffalo ministation hdd in mac
Watch this video, select FAT file system if you want to use the drive in MAC and Windows
HD-PE500U3/BK-EU does not work
Compatible
Windows 7 (32/64 bit), Vista (32/64 bit), XP (32 bit), Mac OS X 10.4 or later (*2)
You could download and use TrueCrypt. It's free and has very strong encryption. http://www.truecrypt.org/
Just bought a 500g ministation buffalo one. but very slow in transferring files from computer. As I am using windows xp, should I format to NTFS or keep it as FAT32 as it comes
Keep it at Fat 32 as most USB drives come that way. and any Windows operating system will recognize the drive. The reason that it transfers files slowly is because the USB drives are slow compared to internal drives. Also your USB ports may be of the older variety USB 1, rather than USB 2, but this is a function of *********** board chipset. For instance, many USB drives are coming out with the ad on the box saying compatible with USB 3, but if your machine only has USB 1 or 2, then it can not be run at the higher speed. See: http://en.wikipedia.org/wiki/Universal_Serial_Bus
The disk was working fine until till evening and on reboot the disk is not getting recognized by the OS- Windows 7
Connect it to a different computer. If it still fails to be recognized, then it is a hardware problem. Exercise the warranty to get the device repaired/replaced, at minimal cost to you.
The buffalo 320GB cannot be detected in my laptop but detected on my friends laptop. How is it so?
It is quiet possible there is not enough power being supplied to the usb port on your laptop. Usually, if this is the case, when the hdd is plugged in you hear an ongoing beeping (something not).
Try using a double usb cable as pictured to get the extra required power to the drive.
5helpful
2helpful
2answers
Buffalo ministation
if you dropped your hard-drive and it stopped functioning - high chances that the drive has a physical crash. Best suggestion will be to contact a professional data recovery team if the data on the drive is really important (Coz, they charge a bomb for the recovery) Suggestion would be to talk to drivesavers.com
Top Buffalo Technology Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
