Cobra 29 WX NW ST 40-Channels Base CB Radio Logo
A
Anonymous Posted on Jun 23, 2013
Adjust modulation pot - Cobra 29 WX NW ST 40-Channels Base CB Radio
Mike Charette
Level 3:
Genius:
  • Cobra Master 1,847 Answers
  • Posted on Sep 01, 2014
Mike Charette
Cobra Master
Level 3:
Genius:
Answers
1847
Questions
Helped
490564
Points
2212
2answers
Where is the modulation pot on the dx 919 v 16
did you use a meter when you set the pot? there are two pots to adjust . one for high modulation and they other for low modulation . Apparently you didn't read the schematic good enough.
How th adjust peek modulation on a midland 1001lwx cb radio
VR 2 is the pot you are looking for an now you need a modulation meter. Speak into the mic at the volume you will be talking on the radio. One one one one while adjusting for 100 percent anymore an you will begin distorting.
Can't tell you but if its anything like my 9001z the variables are clearly marked. www.cbtricks.com has your schematic.Go look at it and find the pot or vr turn turn up the modulation.
Adjust modulation pot cb
4 watts on am and 12 on ssb the modulation pot isn't going to help you . go to www.cbtricks.com and get the service manual.
1helpful
Adjust modulaion pot dx919
TO ADJUST MODULATION IN THIS RADIO THE POT IS MARKED
V-16 TURN CLOCKWISE ,CAUTION VERY FRAGIL BE VERY GENTLE SIR
2helpful
I have installed a supermod on my radio clipped d11 and added varible pwr to the delta tune knob it worked fine for a couple of days the varible was touchy now it will key up but will not modulate. i...
  • Why would you cut d11 when you can adjust VR4 and have it sound so much better? When you cut d11 you put that modulation into overdrive. Put that diode back and adjust VR4 for 100% modulation. That is step one.
  • I assume you added variable power from J36. The problem with adding variable power and not switching the pot is that the wires not only have major loss, running to the pot. And two the stock potentiometer tend to burn up if not replaced with a potentiometer that adjust power by itself. Undo this so called "super mod."
  • Start with a 1969 final for better handling of power.
  • Adjust VR4 for 100% modulation.
  • You can pull the ferrite out of the pot next to the final transistor or you can remove j36 and add a 330uf capacitor (black stripe, negative) to the rear and bias the soldier side with a 33uf resistor. Soldier the resistor to the same soldier points of the Capacitor.
  • Adjust L14,L13 and L12 for power.
Regards, Tony
1helpful
Modulation on 1001Lwx midland cb low need to know which pot to adjust
hello,
The limiter is what limits the modulation. Often times there is a pot that you can turn to adjust it. To get more power and swing out of your radio do this DM1 is the mod limiter RVM1 is the mod pot. Adjust this for maximum modulation. Spread the coils marked Lt5/LT12 just a little Spread LT7/LT11 a lot.
Regards, Tony
3helpful
Midland1000cb very littel audio w/stock or powermic,what is the limiter?
DM1 is the mod limiter RVM1 is the mod pot. Adjust this for maximum modulation Spread the coils marked Lt5/LT12 just a little Spread LT7/LT11 a lot
Hope this helps.
Top Cobra Radio Communications Experts
Mike Cairns
Mike Cairns
eradiostore
eradiostore
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
