Can i solve sim card reject problem?
If the phone reject your sim card,there may be two problem with your phone.1)If you used incorrect puk code.The sim rejected message will appears after tries exceeded.The second reason for this,it is because of network lock.If your phone is locked to network,the sim get rejected by phone.So you need to unlock it.It is locked to which country's network.You can unlock it using the Unlock code.Visit the site Mobileunlocksolutions.com get unlock code for mobile phone and unlock it then use any GSM network sim card.You can get remote unlocking service for Iphone from this site and unlock.
SOURCE: sim card rejected / insert sim card
Unfortunately, they usually fault after getting wet. You might want to take it to a local repair facility and have them check the internal circuitry. Best of Luck.
SIM card rejected means the SIM card has failed, it needs to be replaced.
Best of Luck.
SOURCE: my blackberry curve says sim card rejected
my sim chard rejected my mobbil no.9827628156 and sim no.8991674720000926840
You need to do some testing first.
Put your sim card on another phone (should be unlocked or the same provider) and see it it works.
Put another sim card on your phone (should be the same provider sim) and see if it works.
From there you can check where the problem lies.
When i open my nokia 5800 it says sim card rejected what can i do helpppppppppppp
