AudioBahn A4401Q Car Audio Amplifier Logo
Toy Geldenhuis Posted on Mar 25, 2009
VR3 Amp Protection Light problem
Used this amp with my Vibrant sub for almost a year now and never had any problems until just the other day when it just cut out. The protection light had gone on. Shortly after, while I was driving I made a turn and it came back on for a couple of seconds.
I checked the sub and found a loose wire fixed it and it still had the protection light on. This didn't fix the problem. I figured there was something wrong with the earth so re-earthed it according to a Proffesionals opinion.
Now it doesn't work at all. Checked all the fuses I could find. No Problems. Checked all the wiring and no problems. When I remove the sub wires the light stays on and the same thing for the RCA's. But when I remove the remote wire it goes off.
HELP!
Anonymous
Level 1:
  • Contributor 22 Answers
  • Posted on Mar 28, 2009
Anonymous
Contributor
Level 1:
Answers
22
Questions
0
Helped
12497
Points
39
Looks like you have covered all the basics.
The remote wire is the switch that turns the amp on and off. So you are probably just killing the power to the amp.
Sounds like a short in the amp itself if all the input and output wires are disconnected and the protection is still coming on.
2answers
Protect Light On Amp Being Weird
Could try switching right and left subs. If the problem moves to the other side pull the wiring and redo.
Then if the wiring is ok check the sub.
My amp protection light came on one day. Now it won't turn on. What's wrong?
There is more than likely an issue with your amp, it could've happened from a wire being shorted to ground or a damaged sub causing bizarre impedance issues at your amp. Uninstal it and have it bench tested.
2answers
Red light is on and subs won't play all the wires are connected correctly it all of a sudden just stopped working one day idk y
sounds like the amp is in protection mode. try disconnecting the subs and see it the light changes to green. if it does then the subs are your problem. if the light was allways red while it was working then the subs may be disconnected inside the box or have gone bad. try using a diffrent speaker and connect to the amp.
1helpful
2answers
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
I have kikcer amp 1500.1 is workin good for one year whith 4 memphis 15'' and one day just goin in the protection mode when i turn the radio up can you help me please
sounds like your amplifier does not have the power that your subs need check the rms out put on your amplifier and check how much rms your subs can handle if your amplifier has less rms power then your subs theirs probaly your problem that what happens when it kicks in to protection you could in up fring your out put chips in your amplifier not trying to say that the problem but check your rms power make sure the amp and subs can handle the same power
Help!!
Disconnect your speakers and test the amp. If the protection light goes out , check your speaker wires with a meter for resistance and check the speakers for a shorted coil. Hope this helps. If you need further help, post a comment and I can help you further.
1helpful
Power on/off
solidus- Your amp is going into protection mode, try disconnecting the sub and see if the power will stay on then.If yhe power stays on,it is your sub-blown or shorted ect. But if it does the same as before,its to the repair shop. cooltek Mar,4/08
1helpful
Problem with amp...
In virtually all instances where the protection light is illuminated, the amplifier has gone into protection because the output transistors are shorted. To eliminate external wiring problems do the following.
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still goes into protect, the amp likely has blown output transistors.
If it does have blown outputs, it's is likely due to the speaker wires shorting together when the woofer was out of the vehicle.
Top AudioBahn Car Audio & Video Experts
Jerry Naidoo
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
