Kenmore 22422 Top Load Washer Logo
Posted on Aug 22, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Agitator problems I have a Kenmore series 90 top load washer and in the wash cycle the agitator intermittently makes a racheting/slipping sound for about two weeks now, everything else seems to be normal. Any suggestions... Thanks, Danny
Anonymous
Level 3:
  • Master 530 Answers
  • Posted on Oct 17, 2007
Anonymous
Master
Level 3:
Answers
530
Questions
Helped
184072
Points
1609
Sounds like you have some bad adgetator dogs
they are plastic and they sit inside the white adgetator . take that off and you will see four of them. usually you need to remove the fabric dispenser first to take the bolt out of the adgetator out.
Anonymous
Level 3:
  • Master 625 Answers
  • Posted on Aug 23, 2007
Anonymous
Master
Level 3:
Answers
625
Questions
7
Helped
676794
Points
1177
Sounds as if the transmission agitator pawl is slipping. inside the transmission is a gear connected to the agitator. there is a spring loaded pawl that rotates around the center and engages its pawl or hook into the agitator gear for each rotation. either the pawl hook is worn or the agitator gear is rounded off. the transmission must be opened up to see what is a miss
2helpful
2answers
My kenmore 90 series filled with water and went it got to the rinse cycle it quit working and just started making a grindling sound. help please
sounds like the motor coupler broke. it's a plastic piece near the motor and very easy to replace.
here'e a video you can watch to make it easier:
http://www.youtube.com/watch?v=nM4DW2bq7o0
Kenmore 90 series top load washer: won't agitate or spin
Sorry to give you bad news but this sounds too much like the transmission is shot. It's a bit of work to change and probably some luck to find one at a reasonable price, so my advice is to ditch this machine and get another. :(
Joe
12helpful
2answers
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
2answers
Kenmore 90 series with speed selector switch set to heavy duty cycle it works fine any other setting , regular , hand wash setting the agitator makes a loud clicking sound as it agitates
sounds like a transmition problem. does the noise happen when it goes into spin on the other settings? If no noise in the spin cycle on the other setting, then it sounds like a the gears in the transmition internally when bad for the agitation.
Kenmore 90 series washer will get stuck in between cycles
Sounds like the timer has failed. It's a common problem.
Part number 8545379, $83.69 from SearsPartsDirect.com
Agitator
Faultly agitator spline or gear box fault. Regards Advisor
Alexander
vince
