According to my Everstar manual, P-1 is a drainage problem.
EverStar owners manual pg. 16 -
1. Release the drain hose from the ruber clip and pull out the rubber plug, let the drain hose slant down to a water container.
2. Press the TURBO button on the unit control panel for more than 3 seconds and the WATER INDICATOR light begins flashing. It indicates the forced water drainage feature is activated.
3. Waiting until the WATER INDICATOR light stops flashing and there is no water flow.
4. After the water has drained, remember to secure the drain hose and plug in the upright position and clip it to the unit.
The unit will return to normal operation.
....I had to do this and it worked - Good luck!
I too have a problem like this? I can hear the compressor turning on, then off so ten minutes or so, then back on?
I now have this problem as well -- I will try a different power source but I am not sure that is it
We have to have your error codes to help look at the trouble area. P could be power. P1 could also.
A legend is sometimes next to a wire diagram in the wire terminal panel.
Look there and post back.
mine has no Turbo button. is there a solution?
