Please i i want to change a IP adresse of my OCE TDS 400 but i don t have password. can you help me and told me the steps to do for changing the TCP/ip thanks.
SOURCE: gears of war for pc connecting to windows live
To open TCP ports use these steps below:::
To create an application profile for 4.x and higher:
If you need more help:: access this link
http://support.2wire.com/?page=view&article=21
Cheers
SOURCE: DWL-G710 - Not able to logon with standard IP-adress 192.168.0.30
Must have same IP-adress on Router and Repeater 192.168.0.x. Then have cable from router to PC and from router to repeater. Then logon to repeater and the Dlink-repeater SW have a command where you can see available networks. See to that you choose the right one and that channel, name and password is the same as the router. The repeater will not be visible when you search for available networks because it has the same name as the router. I also had to restart the router and the repeater before it worked.
The repeater gives us excellent connection where we otherwise has no connection, so I can recommend it.
SOURCE: HP LaserJet P2015n Printer IP adress
To Me it looks like your printer is set to automatically select an available IP address. If there is no IP available you get the 0:0:0:0 You need a static IP set up for the printer, this will make sure that no one can use the IP. If this is a company printer, get IT to set it up for you. If its your home network you can set this by yourself by either connecting your printer via usb and using the software from HP or if you have an IP you can log into your PC by entering the IP address in the address bar of your browser. You should get the HP page up for your printer. Set the IP from there in the networking section. I hope this helps a little
SOURCE: Revised IP address for Ricoh 2020d
Go to user tools counter. Go to settings. Go to interface. You should see the IP address settings window. Some Ricohs have auto DHCP. Usually I turn that on to get it to recognize your router. Make sure your gateway address is inserted as well.
