Sometimes when I turn my camera off, it will just turn right back on . I have to take the battery out to shut down. also I have the flashing red timer and it stays on all the time flshing on my screen. I have turned timer off but still stays on
Nikon Coolpix S630 Battery Charger:http://www.2deals.net/Battery-Charger/Nikon/Nikon-Coolpix-S630.html
SOURCE: Built-In Speedlight (Flash) will not retract
I haven't heard of this problem but compliments of velocityreviews I came up with this. Follow the instructions below to attach an external Speedlight. Refer to your Speedlight manual for detailed instructions regarding Speedlight operation. 1 Make sure that both the camera and the external Speedlight are turned off. 2 Attach the Speedlight to the camera accessory shoe. 3 Turn both the camera and the Speedlight on. 4 Set the external Speedlight zoom head to an angle wider than 28 mm. If you are using a Speedlight with Auto Power Zoom, set the zoom head angle manually. The COOLPIX5700 does not support power zoom. 5 Set the external Speedlight flash mode to TTL. At this setting, the amount of light produced by the external Speedlight is measured by the camera?s photocell, and the flash shooting range adjusted automatically to ensure optimal exposure. D-TTL flash control (available with the SB-80DX, SB-50DX and SB-28DX) is not supported. 6 Take the picture If the Speedlight Options: Speedlight Control option in the SET-UP menu is set to Auto, only the external Speedlight will fire. If this option is set to Int & Ext Active then the external Speedlight and the builtin Speedlight will fire at the same time. The COOLPIX5700 does not support AF-assist illumination, or red-eye reduction using the red-eye reduction lamp on the external Speedlight. At a setting of STBY (standby), the Speedlight will turn on automatically whenever the camera turns on but will not turn off automatically when the camera turns off. Exact functionality varies with the Speedlight in use. Refer to your Speedlight manual for details. I hope it's of some help BMW
SOURCE: nikon coolpix 2100 camera won't stay on
I've been having problems with the batteries and the camera refusing to start even with fresh batteries. I bought loads of new rechargable batteries and have finally found some that work. Duracell rechargables. Theyr'e brilliant and keep their charge for ages despite continuous use of the camera! Last summer I managed to take 975 photos before the batteries finally decided to give up!
SOURCE: image screen on nikon d40 won't stay on
You have a short in your button board in your camera or a bad button board. Send into Nikon to repair. You can also look on Ebay for the part if your technical skills are up to self repair.
SOURCE: Got wet. Won't turn on
125 degrees is too hot! A camera should be dried buried in a bowl of dry rice for a week, not in a hot oven.
SOURCE: DSLR D90 Built in Flash Will not Stay down..
I know this late but for anyone else who's had this problem. I just fixed the flash on my camera by using a really small1.2mm flathead screwdriver. The problem is that the mechanism that's supposed to catch the hook has gotten off center. Just stick the screwdriver into the little hole on the left side of the flash (right side when looking at it) and then as you turn it you should be able to see the object that's supposed to be catching the hook. Make sure that object is in the correct position and your camera should work again. Hope this helps!!!
