we have a treadmill power LXi and it doesn't work anymore.
The treadmill won't come down on the floor to start exercise.It shows error E 7.
We live in Gympie, 160 km south of Brisbane in Australia.
Can you please give me contact details of a person, that can come out and fix/repair the problem?
Thank you and kind regards,
Johanna
[email protected]
SOURCE: treadmill will incline but not stay up. incline # stays after bed lowers
incline Motor is not working it can be a few different things.
1) may not be any signal from the console which could be a damaged cable(tight the flexible cable from keypanel vs display board)
2) Tight the connector from display board vs lower board ( main motor controller board the console itself has failed.
3) The motor control board may have failed from a worn treadmill belt and deck measure 120VAC input for the board
5) the motor may have burnt out Test try to measure 120VAC.
6) potentiometer geared to the motor adjust it so the console knows what height the incline is at.
7) the gearing can slip, giving the console false information which can cause chassis damage.
Now see the block diagaram that I did , for person like you, for to know how the main motor board has aprox 90% of functions of any treadmills. sincerely. Good luck, G-d bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
