I got a used (but great condition dell dimension 4600 but there aren't any drivers or os installed
Http://www.dell.com/support/drivers/us/en/04/Product/dimension-4600
DRIVERS.
ABOUT Os THAT CAN YOU PURCHASE AT ANY PC-DEALER.
JUST PUT THE DVD IN YOUR CD/DVD-PLAYER 32X OR 64X DVD FOR THE PROCESSOR YOU HAVE.LET WINDOWS DO THE REST
SOURCE: ethernet driver for dell dimension 4600
Hi stefyboy - Below is a link where you can download your driver. After you get to the page just make sure it says Windows XP as the operating system. Then scroll down and click on the + next to where it says network. You want the intel 10/100 driver. I've included a few a ways to install it. If your kinda new to this the easiest is the download to desktop method and just remember where it unzipped it to, you can always move it to a driver directory where you can keep all your drivers for the future.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=DIM_P4_4600&os=WW1&osl=en&catid=&impid=
If this solves your problem PLEASE rate this as fixed. If not, DO NOT RATE YET. Just add a comment letting me know what happened and I'll be glad to assist you further. Thanks.
Jeff
Hard Drive Installation (via WinZip) with HTML Pop-Up Window for R67150.EXE
Download
1.Click Download Now, to download the file.
2.When the File Download window appears, click Save this program to
disk (Windows XP users, click Save) and click OK. The Save In: window
appears.
3.From the Save In: field, click the down arrow then click to
select Desktop and click Save. The file will download to your desktop.
4.If the Download Complete window appears, click Close. The file
name icon appears on your desktop.
Install
1.Double-click the new icon on the desktop labeled R67150.EXE.
The Self-Extractor window appears.
2.Click OK or Continue.
The Self-Extracting Driver Installation window appears and prompts to
extract files to C:\DELL\DRIVERS\R67150.
3.Leave all of the default settings and click Unzip or OK. If the directory doesn't exist, you'll be prompted to create one. Click Yes. A Self Extractor window appears and indicates C:\DELL\DRIVERS\R67150 files were
extracted.
4.Click OK.
Follow the on-screen installation instructions in the window.
HTML Pop-Up With Install Now Button
1.The Dell Software Installation Documentation window appears.
2.Click the Install Now button. A File Download window appears.
3.Click Run this program from its current location and click OK.
The Security Warning window appears.
4.Click Yes. The InstallShield Wizard window appears.
5.Follow the on-screen instructions.
SOURCE: I have two dell computers,
even though the memory stick sizes are the same, and the speed, there are other differences between memory types, such as parity/non parity, 2x32, 16x4 etc. more than likely, the speed of the memory sticks are different. the easiest fix for this is put the slower memory sticks in bank0 and bank1 (logical numbering used) and then the faster memory sticks in bank3 and bank4. this will cause the faster memory sticks to run at the speed of the slower memory sticks. If your sticks are parity and non-parity mix, then you will probably not be able to combine them.
SOURCE: Factory Reset
1 Turn on the computer.
2 When the Dell splash screen appears during the computer startup process, press and hold <Ctrl> and then press <F11>. Then, release both keys at the same time.
3 In the Dell PC Restore by Symantec window, click Restore. Alternatively, press <Tab> to highlight Restore, and then press <Enter>.
4 When a warning message appears stating that all data will be lost, click Confirm, or press <Tab> to highlight Confirm and then press <Enter>.
The Progress window will appear. Once the restore process starts, Dell PC Restore by Symantec usually takes about 8 to 10 minutes to finish.
When the restore process is complete, the following message will appear:
The system recovery process was successful.
5 Click Finish or press <Tab> to highlight Finish and then press <Enter> to restart the computer.
The software is now installed as it was when the computer was first received
SOURCE: ethernet controllers for dell dimension 4600
You can download the driver you need from Dell here. The page also gives you installation instructions if you run into troubles.
Please give this solution a good rating if it's been what you needed (fixya's are nice!). Thanks for asking here!
SOURCE: adding Dell Dimension 4600 to existing wireless network?...
Go to Staples and purchase a Linksys USB wireless-G (only G needed - the new "N" protocol is overkill) adapter (~$60.00). Insert the Linksys CD and follow the instructions. When prompted, plug the USB adapter into the Dell (frt or back) doesn't matter. If his "roomies" have security enabled on their router, you'll need to know the level, password/passphrase, and the network name that they assigned.
Good luck.
gurutim
