Question about RCA CC6151 Camcorder
CLASSIC RCA AUTOSHOT VHS CAMCORDER.(DSP3) PROBLEMS
Hello. I know this is old school guys. But I really enjoy film. Heres my prob. I need to clean the interiors of this camera. How do I locate the "heads" and other important parts that make the camera pick up the images from the tape. Basicly where are these parts? How are they located? PLEASE HELP... THANX GUYS and GALS. ~ SALLY
Vernon Taylor
  • RCA Master
  • 7,446 Answers
The vhs camcorder has very complex mechanics and hold many traps for the inexperienced.
I suggest you begin by obtaining a standard vhs recorder and remove the cover to expose the interior and then study it. You will find the engineering and interior geography of your camcorder similar.
The round shiny barrel-shaped thing contains the record and playback video heads and the sound head is separate and looks like a larger version of what can be seen in a standard audio cassette recorder.
The interior must be extremely clean, the drive belts in good condition and the clutches and rubber rollers also in good order.
Posted on Nov 16, 2017
5 Related Answers
Anonymous
  • 6966 Answers
SOURCE: RCA cc540 VHS camcorder
Hi, Try running the camera using the AC power (charger) instead of the battery. If the viewfinder works then, it is possible that the replacement battery somehow is not suited for your particular brand/model and is not capable of supplying all the need voltages/power. Try continuously charging the battery for 16 hrs at least to see if this will correct the problem. If even in using the AC power (adapter) instead of the battery, the view finder is still off, then you have a camera fault. Normal problem for this is the thin flexible flat cable that attaches the screen to the electronics inside the camera. In some case, it is the backlight of the display that is at fault. Either which would require the services of a qualified professional. Hope this be of some help/idea to you. Good luck and kind regards.
Posted on Aug 24, 2007
Anonymous
  • 320 Answers
SOURCE: need unit to put tape into, to play in vcr
What you need is a VHS C adaptor. I did a Google search and found at least 10 sites selling them. Rather than cut and paste, I suggest you go to Google and type in "VHS C Adaptor".
Posted on Oct 29, 2008
techman007
Lavell Turner
  • 1112 Answers
SOURCE: camcorder won't record
Check the tape and make sure the record tab is still on the tape and has not been removed. If the record tab has been removed then use a new tape for recording as the unit will not record. This tap is usually on the lower left end of the back of the tape. When the tap is present it closes a record mode switch letting the system know the tape is able to bv recorded on..
Posted on Dec 27, 2009
Anonymous
  • 1177 Answers
SOURCE: How do I upload my
You can get videos from this camera, or any analogue video source, into a computer. You just have to play them into an analogue video interface port. These are available as expansion slot cards for a PC, or sometimes as a USB plug-in interface. They will come with drivers and probably software to digitise the video input and record it to a file. Lots of third party video editing software will also be able to accept the input from this kind of port. You don't need any "driver" related to the camera, it is just a video signal source. The connecting leads will be standard RCA signal plugs, like the ones you use to connect to a TV or VHS recorder. You probably already have a lead for this.
Once you have the video on the computer, you will need DVD "Authoring" and burning software, which will usually come as part of the same package. You can download such software for free from the internet- my first stop would be www.download.com.
Posted on Jan 14, 2011
Anonymous
  • 26 Answers
SOURCE: I have borrowed an old
It sounds like one of my older, been-in-storage for awhile, camcorders. When they sit for without being used fairly regularly, there is often a bit of dampness that settles into the camera. If left in a warm room, this may help dry it up and allow the open/eject function to work. To help it get un-stuck, you could gently press inward on the door (do not pry outward) and try to loosen it up. It may take a few times with this process to allow the door to jar loose.
Posted on May 16, 2011
Nikon FM10 will only release shutter with cable
Hello Blair,
I too like old school camera, mine are the N2000, N6006, N80, and F100. First without film in the camera I would attempt to release the shutter. If it does then there is something going on with the film transfer causing a bind.
However, If it continues not to release the shutter I would put the FM10 on the shelf then go to KEH.com for another. Just now checked KEH.com, 2014-05-26, a FM10 in EX condition is $89, EX+ condition $99. That would be a much better move than repairing yours and less expensive.
Cordially
May 25, 2014 | Nikon FM10 35mm SLR Camera
This Yashica FR's film advance is loose and does not wind the film, the shutter button does not work either! It has a new battery in it. Any help would be greatly appreciated. I'm not sure if I'm miss
yashika is a really cheaply built brand of camera, they always have been. as cheap as they have gotten now you might as well come up to the digital age. but if you are one of those hard core old school photographers then you can find some good canon, nikon or pentax film cameras on ebay really cheap. i wouldn't mess with this one any more
Feb 22, 2013 | Cameras
Help!!! i have a rented vivitar film camera from school.... 3800 N..... with a dead battery!!! i can't figure out where the battery is located??
The battery compartment is on the bottom of the camera. Use a coin to turn unscrew it.
If you need one, you can download a manual from
http://butkus.org/chinon/vivitar_cameras/vivitar_v3800n/vivitar_v3800n.htm
Nov 08, 2010 | Vivitar V3800N 35mm SLR Camera
I just bought a camera from craigs list, there was still film in the camera and I took one picture and now everytime I look through the viewfinder it is black, like if something is covering it. I took the...
SLR stands for "Single Lense Reflex", and yours is not reflexing, the shutter is stuck. I would say the guy that owned it before you did not know it, because to reset it manualy you have to remove the film and or the lense. To fix it you have to send the camera in for a good cleaning. "proffesonal job, lots of small tools and touchy parts"
Sep 06, 2010 | Pentax ZX-50 35mm SLR Camera
Photography Class Camera
Hello, depending on the class he is taking you may find that a normal digital camera will suffice. Most camera classes and courses now use digital, unfortunately the old film cameras are becoming a thing of the past. If your son is a mad keen photographer then I would consider investing in his future and buy him a good quality digital SLR. I hope this is somewhat helpful.
Nov 04, 2009 | Minolta Maxxum 5000 35mm SLR Camera
Shutter release and film and advance not working on Olympus OM-N1
for shuter ,the spring ,or mirror lock wornout,rebts in shuter may wornout,for film advance lever cheek for rewind buton on botm
Apr 15, 2009 | Photography
I want to know how to rewind a film reel or reverse an Elmo FP-A movie projector. I have an old Elmo FP-A movie projector that works fine. I do not have the instruction manual that would explain how to...
There are 3 round knobs and 1 Autostart switch on the control panel. The key to rewinding this machine is by pushing the gray button down, while turning the Motor Knob to the "Run" position. Of course you'll need to start the original film back on its reel, directly. (Do not thread the film as you would normally.) BTW, you can show your films in reverse by using the Reverse button on the motor switch while its running. Hope this helps. Now, if I can find someone who can guide me in re-assembling my Elmo projector's lens, which I dis-assembled in order to clean the crud off the multi-lenses in the main lens unit itiself.
Mar 10, 2009 | Fuji Photography
Changing battery in one600 camera
The battery is in the film pack. The one600 doesn't use any other type of battery except what comes with the film.  Either the film is really old and the battery died or it's defective.  If the film is relatively new and you haven't been able shoot all 10 shots, then you might call the manufacturer for a replacement.  Otherwise, I'd buy a new film pack.
Mar 03, 2008 | Polaroid One600 Ultra Instant Camera
View finder
Had same prob with Cyber-Shot cam. manufacture prob. Sent my to repair for free. Repaired for free. Cant remember where I found link to site.
Sep 17, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
RCA CC6151 Camcorder Logo
Top RCA Video Cameras Experts
Lawrence Oravetz
ADMIN Canada
ADMIN Canada
Are you a RCA Video Camera Expert? Answer questions, earn points and help others
