Apple iPod MA446LL/A MP3 Player Logo
Posted on Aug 22, 2007
How can i find the code of the volume in my ipod?
I want to increase the volume of my ipod, however, i could not open the volume as there is a code in it. I tried different numbers but it won't open.
I cant increase the volume !!
micro switch needs replacement, it has worn out.
JBL200id ipod dock, random increase of volume
If you have a case on your ipod with a sleeve over the volume slider, it could be the case. Have a similar problem with mine. Best thing to do is to clean your case and Ipod really well.
If you dont have a case, then I have no clue.
I have a problem with ipod it was asking code for increase volume
What has happened is someone or you have put a code on your ipod for the limit of the sound. If you dont know the code then you will have to restore you ipod to get rid of it. I suggest backing up your ipod before hand or you will lose all of your songs
When I try to adjust the volume on my Ipod Nano under Settings it is asking me for a code. How do I reset the code or find out what the code is? Is there another way to increase the volume, it appears to...
moz-screenshot-8.pngmoz-screenshot-9.pngthat is not a problem follow the steps below and if it doesnt work let me know i will assist you from there. unfortunately the password for the volume lock is whatever you set it as but you can do this. Plug in your iPod and iTunes will open ( or open it youself)Select all you songs by clicking ctrl and A. (PC's: Ctrl and A at the same time. Mac's: Apple and A at the same time.) Right click your songs. Click "Get Info" Click "Yes" Click the "Options" tab Check "Volume Adjustment" Put the Curser all the way to "+100%". Select Ok! Hidden Folder for Mac's Enable hidden folders. If you go into Terminal and run these two commands all the hidden files appear when you open Finder. defaults write com.apple.finder AppleShowAllFiles TRUE killall Finder To get back to hiding hidden files use these commands defaults write com.apple.finder AppleShowAllFiles FALSE killall Finder Navigate to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, delete the file named "_volumelocked". Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Hidden folders for windows PC Enable hidden folders. In Windows explorer,go to "Tools", "Folder Options". Then click on the tab called "View", and under "Hidden Files and Folders", click "Show Hidden Files and Folders". Navigate ("My Computer" to double-click on the icon of your attached iPod) to the hidden folder named "iPod_Control", and once there click on the folder "Device". Once there, copy the file named "_volumelocked" to a folder on your hard drive then delete it from the iPod. Eject your iPod. Then, restart your iPod. You can do this by holding down the center and menu button for at least 6 seconds. If using an iPod Nano, hold down the center button and menu button simultaneously for about 10 seconds. Once your iPod has rebooted, check and make sure that it worked. Simply go into "Settings", "Volume Limit". If it asks for a PIN, you did it WRONG. Retry the above procedure.
Warning: Note that some methods may not work on all iPods. Not all ipods have the file called "_volumelocked" it is impossible to get better sound on some of the ipod gens, for example the 5g 60-80 gigabyte ipods. Don't Listen to music too loudly. It will destroy your hearing. Don't delete any more files than necessary as it may prevent your iPod from working
2helpful
Volume stays low won't increase
Your volume limit on your ipod is probably set low. To check it, go all of the way to the ipod's main menu and go to settings. Then go to volume limit and put it where you would like it to be if it is too low. Then go back to your music and play it. Turn the volume up to your liking and it should work and play louder.
Volume will not maintain level
To fix the problem, I reset the iPod.
45helpful
2answers
Ipod nano volume control
Try
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
3answers
Ipod Nano can't unlock volume lock
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize. Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the iPod, which will erase all music and data."
11helpful
9answers
Adjusting Volume on my Ipod Nano
If it is the unlock code plug your ipod into itunes then goto to settings for the device and click change password
Top Apple Audio Players & Recorders Experts
Marvin
Marvin
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
