At the welcome screen of windows ? if so
1. repair your OS ,google it youl find a loot of things about it
2 reinstall your OS.
SOURCE: laptop won't boot
Shut the computer down and restart it pressing F8 and select safe mode login under administrator with no password click run type msconfig, select start up, select disable, select apply, select restart, and try to boot normal. It sounds like there is a malicous code running is the background.
Or if you have enoufgh time when the computer loads quick click run and type Shutdown -a this is a shutdown about comand and it may stop it.
Let me know if any of these work and i will tell you how to fix it permanetly.
Hope this helps
NosirromNet
SOURCE: Laptop system disks
try google search, theres a lot of it. or you can try: www.pcmech.com or newegg.com this is where cheap hardware are sold.
SOURCE: Lid switch location??????????
HP DV 5000 LID switch location is here:
If You want test lid switch, just connect A+B together for a monent!
If the monitor flashes on...? Lid switch is faulty.
It is too dificult to change the lid switch, so the easiest way is connect these pins together forever. :))
Dont forget to turn off your notebook... he wont sleep anymore ;))
Greetings from Latvia.
[email protected]
SOURCE: My function keys on my
The icons you see on the function keys only work if you press the Fn key (lower left of the keyboard). Otherwise, each key functions just as it should--as a Special function key with a number on it.
