Question about Logitech LX6 Mouse
How do i take it apart ? Are there hidden screws to be found?
    New Friend:
There are a total four small phillips screws on the base of the mouse. Two are in the battery compartment, while the remaining two screws are located beneath two self-adhesive teflon pads at the front of the mouse. Simply remove these pads with a small flat screwdirver or scraper in order to reveal the screws underneath.
Posted on Apr 13, 2010
  • 161 Answers
If this is a wireless mouse the top should slide off to replace the batteries, if not the top then somewhere on the bottom, but somewhere the bateries have to get replaced
Posted on Mar 25, 2009
6ya staff
SOURCE:
How do I get it apart to fix the on off switch?
You have to search for the fixing screws. Very often it's easy to miss one. It could be hidden under a label for example, or hidden down long access holes. Some units don't use conventional "pozzy" screws. They have special screws which require special tools that you can buy once you know what to look for.
Oct 21, 2015 | Audio Players & Recorders
I need to take apart my Brother SE 400 so I can replace the spool pin.
This is general information for all sewing machines. There are often hidden screws inside and clips that can not be seen. You can gently pry the machine apart and see where it is hanging up. Often the screws are reached from the side with a long Phillips screwdriver. You will need a flashlight to see them. Some models have access to the cover screws after removing a knob or the bottom plate.
Jun 20, 2014 | Brother SE400 Computerized Sewing Machine
How do i remove the screen
There are lots of videos on youtube - almost every model is covered as far as I can see.
But basically Ive found two types
- sometime screws are hidden under the rubber bumpers at the screen corners or sometimes under small pieces of plastic you have to remove to expose the screws.
- but sometimes unfortunately there are No screws and you have pry the screen apart - I use guitar plectrums as they do less damage.
But check youtube for your model
Dec 21, 2013 | Computers & Internet
I can not open my "key fob" to replace the battery, does anyone know how to open it?
hey,, There are hidden clips inside you just need to pry it apart... some of them the back cover slides off, but most just pry apart. Look at the back and make sure there are no screws and no hidden screws (like those under rubber stoppers, the stoppers must be removed to expose them).. any way once thats verified, simply insert a flat head (blade) screw driver in between the seems and pry it apart.
Dec 28, 2012 | Cars & Trucks
The power jack has come loose inside of the Acer Aspire one Kav60. I think I can access it by removing the screws from the bottom of the unit then tighten it up. I removed them all but the top would not...
Hi Jim, I can only surgest you search on the web for info on seperating parts & manuals, some do snap apart, some have "nasty" hidden screws under lables, (I had to break the case on my SHITEPSOM printer to repair that) one laptop had one tiny screw under a piece of tape, under a hard drive, it held the keyboard in, why????? God knows!!
Good luck Jim.
Ray
Jan 02, 2018 | Computers & Internet
ENGINE WILL NOT ENGAGE WITH SPINNING SPOOL
I had the same problem, The pully is plastic and is mostlikely melted. I took mine apart when it finally stopped working and found that the belt had broken as well. When taking it apart, there is a hidden screw under the black sticker label. Just feel for the soft spot. Also, there are screws under the black plastic embelishments.
Apr 18, 2010 | Black & Decker 14" Grass Hog Xp...
Replacing power cord. How does cannister come
I found the hidden screws under the cord rewind and power buttons.
Oct 09, 2009 | Riccar Vacuums
Getting the monitor apart
It is clipped on, or there is a hidden screw underneith a sticker or something.
They make these things hard to disassemble for a reason. There is very little you can do one you've got it open. There's almost nothing inside that can be serviced by any normal user.
Jan 23, 2008 | Sceptre X9G-KomodoV (Black) 19 inch LCD...
Wingman Contacts Dirty, Cannot Open Cover
The the ring with 5 like screws is just cover that can be gentle forced out with a flat screwdriver. Then comes off the power control and the rubber gasket. Finally the top cover comes out. Simple.       coco13cos(Romania)
Jan 03, 2008 | Logitech WingMan Extreme Digital 3D...
Logitech LX6 Mouse Logo
402 people viewed this question
Top Logitech Computers & Internet Experts
Ekse
Alun Cox
Robert Stout
Robert Stout
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
