Hi there I have a problem with my Hooover 200M. The water seems to only dribble into the washing machine. I have taken off the top and tested the actual hoses and found that the pressure is fine from there. I have also checked from the actual jets that attach to the what i would call an exit valve or exit house which is basically where the water exits into the washing machine. As soon as I plug it into the "exit valve" it just dribbles out. But as soon as I take the jet out from the valve the pressure is fine. Its really odd. If anyone can help it would be muchly appreciated.
Hi All
The solution is a faulty solenoid valve, either the hot or cold valve depending what temperature you are using.
Replacing the valve is easy turnoff machine unscrew hose, remove 3 srcews to lift control cover, slide out locking tab, unclip wires the replace valve which cost about 30-$40
Tobor
Posted on May 08, 2008
See tobor1's solution - worked easily. I only use cold water - I followed his instructions and swapped the cold & hot water solenoids around - simple. Took 5 mins and cost me zero $.
Posted on Nov 09, 2008
I want map of parts of hoovers models no hwa2000g
Posted on Apr 01, 2008
Just helped neighbour call mechanic, for 200m, found closed water valve inside machine.
cost $50au to replace.
Posted on Apr 07, 2009
It sounds like the dipenser box is blocked where the water flowsthrough the box. Regards Advisor
Posted on Aug 22, 2007
I have taken out the dispenser box it is not blocked. It is something to do with the water pressure. As said I test the jets they are fine. Than I plug into the dispenser box and it dribbles out. Now this is the weird part- I put the jet into the dispenser box while its shooting out water fine than it start to dribble out the box i than took the jet out again and found that the jets are now just dribbling out. Your help is very very appreciated.
I have the same problem just started does any one know how to fix it!!!!
