Watched the tv last night, shut it off...got up this morning and not even a standby light....no power surge or storm. just quit
SOURCE: Post Storm Problem
Hope is last to dye. Be calm and contact the technician with best references or Authorized Sony Service. If you need more info please advice
SOURCE: tv no sound no pictures power light blinking
There are a couple of things you could check on this one if you have the equipment and are somewhat skilled in electronics.
Take a test meter if you have one, if not try the local radio shack. Unplug the set and remove the back. Locate F802 a small pico fuse in the SMPS 4a/125v. Test this for open - if open replace it...
Next locate Q472 ( 2SC1740 ) a common NPN amp transistor which will cross to NTE85 in a pinch. This transistor is in the shutdown circuit and if it's failed usually causes the conditions you have there..
Try at least these, and if anything here sounds the slightest complicated take it to a shop - it should be a rather inexpensive repair...
Bill
SOURCE: tv won't turn on
i can' turn on my sony tv . no lights are blinking. nothing. could something when it was moved.
SOURCE: watched tv last night - ok.Turn on tv in the
YES common fault you need new lamp located behind cover on side or front the front one is a little harder to get to if you have book shows you how.
The model number will be on old lamp look at lamp will be white or blown WHEN GET NEW LAMP DONT TUCH GLASS after replaced pic and sound will be ok
Testimonial: "Thanks. Changed lamp about a month ago. Seems to be a different problem. I left the tv off for about 8 hours, turned it on and the volume was back."
SOURCE: My Sony Trinitron shut down last night. I
What is the likely problem if the Standby lights blink twice.
Thanks
