Wolfgang Puck Electric Pressure Cooker Slow Cooker Logo
k.williamson Posted on Jun 21, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oxtails how to cook oxtails and how long
Laura D.A. Pazzaglia
Level 2:
New Friend:
  • Expert 190 Answers
  • Posted on Dec 10, 2013
Expert
Level 2:
New Friend:
Answers
190
Questions
0
Helped
103367
Points
234
The pressure cooking time for Oxtails is 45 minutes at high pressure. Here is a detailed chart with cooking times for all types of pressure cookers:
http://www.hippressurecooking.com/pressure-cooking-times/
Tower slow cooker model no 3834-0. Not sure which is hi or low when pressing the switch as I have been told low is opposite when pressed to high??
If timing does not allow the recipe to be cooked on low for as long as required, the slow cooker can be turned up to high and the cooking time reduced. Convert cooking time by using a ratio of 2 hours of cooking on low as being equal to 1 hour of cooking on high.
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Blodgett Convection Oven: Cook High, Cook Low, and Cool Down?
Cooking at low temps results in better taste for most things. As far as cool down goes I would have no idea.
I have a prolectrix slow cooker and the only two settings on it I want to cook a lobby do I leave it on warm or cook I'm confused
The Cook setting is High heat for cooking the Warm setting is Low heat just to keep it warm after cooking is done, really hope this helps?
I pushed the cook time button but it still says zero what do I do
Hit the on/off button, so that the cooker looks like it is off, then hit the cook time button up the the number of hours you need to cook. This slow cooker has three settings: LOW, HIGH and WARM..... When your corningware slow cooker is initially plugged into a wall outlet, the display will show "0". This display indicates the programmed number of hours for which ameal will cook. The slow cooker can be programed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears. If 1,2,3,4,5, or 6 hours are selected, then the slow cooker will operate on the high setting. If 7,8,9, or 10 hours are selected then the slow cooker will operate on the low setting. To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the warm setting.
May 11, 2010
Please tell me how this appliance works. Thank you. Mary Jane Howroyd Kitchen Aid Crock Pot
Make sure that what you are cooking is something that can be cooked in a slow cooker. Put all the ingrediants into the pot, plug it in and set it to either Low -This setting is the most used setting. Usually takes 8 hours or so depending on what you are cooking. High -This setting is faster and usually cooks in half the time as Low, but meats aren't as as tender cooked on this setting. Also make sure you put in enough liquid. You usually want the pot filled 2/3 with whatever liquid you are using to cook with.
What is the cooking time for "slow" and "fast"
The cooking time depends on what your cooking. In general there is a 3 to 4 hour difference between slow and fast. If your cooking poultry make sure to check the meat with a thermometer until you get the hang of it.
1helpful
Whats the differences with the low high and auto settings on a slow cooker which setting is considered best for cooking stews
The difference is the time and how warm it cooks. Low cooks a slow, lower heat - cooks 6-8 hours. And High is a faster cook at 4-6 hours. I tend to use low for stews and chilis.
I'm cooking a 7 pound beef rump roast. It has been recommended that I cook it for 7 hours on medium. I only have a high and low setting. How long should I cook it on either or both settings.
if it is recommended that you cook for 7 hours on medium I would think the you would cook it on high for 3-1/2 hours, and or low for 14 hours but check it with a meat thermometer every hour
2helpful
Can't change temperature-stays on "warm"
Push the COOK TIME button, if the time changes then if you leave the number of hours between 1 and 6, and press the ON/OFF button, it will cook on high that many hours. If you leave the number between 7 and 10, and press the ON/OFF button, it will cook on low that many hours. If you leave the number at "0" then the slow cooker will cook on WARM. If the COOK TIME button does not work, unplug the slow cooker, hold both the ON/OFF button and the COOK TIME buttons down and plug it into a wall socket. After the lights flash a few times, release the buttons. the switches should work.
Top Wolfgang Puck Crock Pots & Slow Cookers Experts
Ngoro
Are you a Wolfgang Puck Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
