Question about Sony Playstation 3 (PS3) Console
Try safemode
hold down the power button while the console is in standby. the light will go from red to green.it will beep once flash green beep again, and then beep a third time. after the third beep the light will turn red.
once the light is red, take your finger off the power button and place it back on the power button. the light will go from red to green, beep once flash and then beep twice quickly. after it does the double beep, take your finge roff. the light will stay green and you'll get a screen asking you to connect the controller.
after connecting the controller, try option 3, or whichever option is restore filing system. this can possibly correct media loading and will 95% of the time fix the console when it freezes before loading up your icons(the xmb)
Posted on May 20, 2009
SOURCE: Cannot Start. The correct hard disck was not found.
take it back to shop and get new one
Posted on Mar 28, 2007
SOURCE: ps3 display this message cannot start the correct hard disk was not found
When do you get this problem? You need to make sure you are properly configured for internet access. Also, update to version 2.2 (came out last night) and that should solve all of your problems. Good luck!!
Posted on Mar 25, 2008
SOURCE: cannot start the correct hard disk
i cry i have to send it to sony wha
Posted on Sep 18, 2008
SOURCE: Cannot start. The correct hard disk was not found.
u will have to get a new hard drive i would get this one it is cheap http://www.walmart.com/catalog/product.do?product_id=10710953
you will have to take the cover off the hard drive.
Posted on Jun 30, 2009
SOURCE: PS3- cannot start. Correct hard disk not found.
when your ps3 is standing upright the tall way tip it over and look at the bottom there should be a plate that says something about the hard drive. get a flat screwdriver and pry on the right side of the plate. The hard drive is directly behind that plate and is secured by a blue screw. take out the screw and flip out the little u shaped handle and slide it to the right and pull out your hard drive. Try blowing out all the connections and putting it back in hope this helps
Posted on Aug 07, 2009
Mar 03, 2012 | Sony Playstation 3 (PS3) Console
Nov 26, 2011 | Sony Playstation 3 (PS3) Console
Mar 27, 2010 | Sony Playstation 3 (PS3) Console
Nov 17, 2009 | Sony Playstation 3 (PS3) Console
Aug 19, 2009 | Sony Playstation 3 (PS3) Console
Jun 30, 2009 | Sony Playstation 3 (PS3) Console
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
Jan 02, 2009 | Sony Playstation 3 (PS3) Console
Jun 26, 2017 | Sony Playstation 3 (PS3) Console
Sep 01, 2008 | Sony Playstation 3 (PS3) Console
565 people viewed this question
