Question about Dell OptiPlex GX260 PC Desktop
User running WinXP pro on Dell Optiplex gx260 goes to work and local HD not listed, network drives show, under all program all apps gone. When user tries to reboot gets message "user not authorized to restart computer." Only solution is to power off then back on and all then ok. Has happened 3 times in last 7 days. System left on 24hrs and this usually happens when they arrive to work in the am. No virus or malware listed after scans with both AVG and malwarebytes. Any ideas?
Posted by kmcg2005 on
  • 1 more comment
  • kmcg2005 Mar 31, 2009
    Yes this is on a domain but there are no policies setup. There are 10 workstations and this is the only one having this issue.This started happening after they upgraded their QB to 09 and then installed a multifunction samsung printer/scanner /fax. I am leaning towards the samsung as the culprit. To alleviate the problem I replaced the workstation and made sure the samsung was installed correctly on the server. The dell has taken up too much time already. Thanks for your assistance.
  • Anonymous May 11, 2010
    I have to agree with inthecellar, it sounds like a group policy object has been applied to this user's computer. See if the user can log on "locally" to the machine, meaning in the third drop down at the login prompt, choose (this computer). If the user can login locally to the machine then group policy wont be an issue, see if he can restart the computer as a local user....and not a domain user.
    Serge
  • Blue Sky IT Strategies
    Blue Sky IT Strategies May 11, 2010
    If this is on a domain do you have any policies setup that might be propogating down to clients over night?
Anonymous
Dell gx260 lan driver free downlod
Posted on Apr 27, 2009
I have a Optiplex Gx260 which has only 800mb of memory left. I have removed all unused programes but it seems that the hard drive capacity is being taken up by things which arn't clearly identifyable.I...
One drive should be set as master, (the bootable system drive) and the extra drive as slave. Disc management should be able to initialise it then and format as required.
If you install iobit.com and asc-setup, (it is free ware) run the regisrty utility followed by disc cleaner, that will show you where your space has gone. All useful stuff can be stored on the slave disc.
Hope that helps.
Feb 25, 2011 | Dell OptiPlex GX260 PC Desktop
Booting Problems With Dell Optiplex gx270 and gx260
Does anything show up on the screen when you access your BIOS?
Have you tried a fresh install?
Are there two video adapters installed (one integrated and the other in the AGP slot?
Oct 14, 2009 | Dell OptiPlex GX270 PC Desktop
I have a network computer that I do not know the windows login fo
Go to user accounts
Remove all users but 1, and set the password Blank
Sep 05, 2009 | Dell OptiPlex GX260 PC Desktop
Dell Optiplex GX260 will not shut down.
Could possibly be virus/malware issue. Try running a full scan to see if anything is found.
Mar 30, 2009 | Dell OptiPlex GX260 PC Desktop
Trying to copy harddrive to another harddrive. want to move to larger drive. problem is optiplex gx260 convertible desktop only shows 1 harddrive in my computer. only a c drive shows up. the secondary...
To clone a disc , acronis true image home is a very good software . A free software based on it is available from seagate called as disc wizard but it will only work with seagate drives. about hard drive not being detected , try upgrading your bios . Some bios dont detect new higher capacity harddrives. Do tell what is your drive capacity.
Mar 21, 2009 | Dell OptiPlex GX260 PC Desktop
Hard drive problems with Optiplex GX260
You should be able to manually enter the drive perameters into bios. That should let you boot. Or boot it up with a boot disk.
Dec 22, 2008 | Dell OptiPlex GX260 PC Desktop
Computer does not see hard drive or cd rom
Use separate cable for both the hard drive.
Make master to the one which is bootable,restart your system and just check bios setting whether both the hard disk are detected or not..also under boot device check first boot drive is hard drive which is master and bootable..
Jul 21, 2008 | Dell OptiPlex GX260 PC Desktop
Pc cycles on and off
You may try running a diagnostic on your hard drive to make sure it is in good working condition. Most Dell computers have a built-in diagnostic program, if you press F12 at boot, you should be able to access that.
May 21, 2008 | Dell OptiPlex GX260 PC Desktop
Installing a sound card into my Optiplex GX260
Hi
OptiPlex GX260 can be Small Form-Factor, Small Desktop or Small Mini-Tower. Compatibility with PCline 5.1 PCI depends on the profile of the PCI Card and the Profile of your OptiPlex.
GX260 Small Form-Factor is compatible with Low-Profile PCI Cards only. GX260 Small Desktop and Small Mini-Tower are compatible with standard PCI Cards. (Small Mini-Tower however uses a PCI Cage).
Check OptiPlex GX260 Systems User's Guide - http://support.euro.dell.com/support/edocs/systems/opgx260/en/ug/index.htm
From here you visualize the 3 form factors. Also there is info and steps to install PCI cards.
NB:
1. Generally, upmarket PCI cards are standard height. Some manufactures supply a metal piece to allow it to be used in Low-Profile or Standard Profile.
2. Driver software needs to be installed after the hardware is installed.
Mike
Apr 12, 2008 | Dell OptiPlex GX260 PC Desktop
Dell OptiPlex GX260 PC Desktop Logo
172 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
