Canon PIXMA iP4200 InkJet Photo Printer Logo
Posted on Aug 22, 2007
'paper jam' error on canon pixma ip4300
My printer will not print as it keeps showing a 'paper jammed in outlet slot' message. i have checked this area and these is no paper jammed. when i turn the printer off and then back on it feeds a piece of paper through without any problems but then brings the paper jam message up again. can any one help
  • 14 more comments
  • black_sheep Nov 07, 2007
    Its the same for me! It just wont stop! and mine wont feed from cassette either!
  • Smiley Rowe
    Smiley Rowe Jan 10, 2008
    does anyone know how to fix thre paper jam problem???????
  • Anonymous Jan 12, 2008
    Same for me. Orange light flashing 3 times. No paper jammed anywhere. Feeds one sheet through, then the flashing starts again...
  • Anonymous Feb 17, 2008
    Same problem. Printer keeps registering paper jam at output slot but on checking thoroughly there is nothing jammed there, or anywhere else. Please help.
    Thanks and regards, Gordon
  • Anonymous May 30, 2008
    same here... Solution doesn't seem to work :(
  • Anonymous Jun 18, 2008
    Hi gordonthe1
    The fix you posted worked for me too, but only if I use a heavyweight card.
    I also get a lot of screeching......but still, it's a start.
    Mine is a Pixma ip5000, thanks for the tip.
  • PostcardPro Sep 04, 2008
    I have the same problem on my ip5000. I am also getting indicator that there is no paper in the input tray when there is.
    I tried the suggested solution (although the printer doesn't eject the paper on its own) and it helped, but I am printing 500 4X6 sheets and it is taking forever since the fix seems to help for only 10-20 sheets on average. Then slowly these two problems increase in frequency after another 10-20 to the point where I have to repeat the solution.
    I am also trying cleaning the two rollers at the bottom right of the input feeder. It seems to be only temporarily helpful as well.
    Any other ideas? Any other printers that might be able to handle this kind of printing better?
  • rhondylynn Dec 08, 2008
    i have this problem. my iP4200 keeps saying there is a paper jam in the paper ejection slot with the error number 1300. but there's nothing there!
  • Anonymous Jan 10, 2009
    PIXMA IP4300 gets jammed
  • mdickinso18 Jan 14, 2009
    paper jam
  • bonny anne Jan 21, 2009
    same problem with a Pixma ip4200
    never any problems,
    but now it refuses to transport paper
    tried the plastic sheet trick, it went through,
    but didn't solve the problem
  • Anonymous Mar 12, 2014
    I have a canon pixma mg5320 and it keeps saying that it has a paper jam in the output slot but there is no paper in it at all not even a little piece. How could I fix this
  • Anonymous Mar 23, 2014
    When I go to print the I get a error out of paper message and it won't feed the paper when I restart print
  • Anonymous Mar 27, 2014
    Paper jam problem. we have cleaned the printer but still a message comes "paper jam"
  • Anonymous Mar 28, 2014
    Paper jam is showing on screen after checking where the paper is jammed and looked in other areas to, there is no paper jammed but message still shows on screen
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Mar 04, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
16416
Points
26
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 26, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
16240
Points
Same problem with my Canon Pixma MP 480 - printer is jammed error message with nothing visible jammed in the printer. Turning on/off would not help.
I used the solution by gordonthe1, but instead of using a plastic sheet I pushed a very thick & stiff paper sheet up the rear. I had a very difficult time getting the sheet past the 2nd set of rollers - the rollers would lift for a split second each time I turned the printer ON, but even then it took a violent shove on the third try to finally get the paper through. Then, I (very roughly) yanked the paper up through the top of the printer before letting the printer eject it again. I also finished a roller cleaning, which I could not do before because of the incredibly frustrating non-existent paper jam. Now the Printer seems to be working perfectly & I'm thrilled that I won't be tossing my printer.
Anonymous
Level 1:
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
16240
Points
A shot term tip is to feed a piece of paper the wrong way through the machine, turning the rollers. when you shut the lid the paper comes out. but you have to do this every time, not funny.
1 Related Answer
A
Anonymous
  • Posted on Aug 20, 2008
SOURCE: 'paper jam' error on canon pixma ip4300
ring canon support on 0844 369 0100
or try
support.canon-europe.com
they suggested i do a roller cleaning - but i cant find this option ?
4helpful
Cannon Ip4300 - Orange light flashes on printer.
A possible paper jam has happen on the unit. Did you have an paper jam error before you have this problem?
You must clear any paper jam on the unit, check the unit for any stuck paper or object or check if there was misaligned parts inside.
Let me know for any clarifications.
Thank you for using fixya.
micro-
Canon Pixma MP160 shows errors E3 and won't print
Error E3 : Check if the paper has jammed in the machine, reload the paper in the machine correctly and then press [Black] or [Color].
Paper Jams :
Cause : Paper jams in the paper output slot/ Auto Sheet Feeder.
Landscape Credit Card sized paper jams inside the machine.
Action : Remove the paper according to the following procedure.
1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the paper output slot, whichever is easier.
* If the paper tears and a piece remains inside the machine, open the Scanning Unit and remove it. Be careful not to touch the components inside the machine at this time. After removing the paper, close the Scanning Unit, turn the machine OFF and turn it back ON.
* If you cannot pull the paper out, turn the machine OFF and turn it back ON. The paper will eject automatically.
2) Reload the paper into the machine and press [Black] or [Color].
* If you have turned OFF the machine in step , you will need to retry printing, because this operation cancels any print jobs in progress.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, contact a Canon service representative.
Important : You cannot load Credit Card sized paper in the landscape orientation.
Hope this helps.
Have a good day.
2answers
My ip4300 printer shows - Service Error A600-
goes through this link and try.........
http://tricks-collections.com/solution-canon-pixma-ip4300-error-6a00/
3helpful
Canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
There's a small white light below the power light that's flashin.
In this case you may have to clear the memory of the printer or set the printer to default.
4helpful
"Paper Output Slot Jammed" Canon Pixma iP4300
These printers are FULL of very sensitive sensors, and chances are that one of them may have a small piece of paper blocking them. If you can get the covers off by finding the "Triangle" arrow markers, you can inspect all these sensors.
Good luck!!!
Service error 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
or try
2answers
Will not function on front feed
check all paper paths for little pieces of paper
old marine
old marine
ZJ Limited
ZJ Limited
