Maytag MGS5770 Gas Kitchen Range Logo
Posted on Mar 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Getting F9 Code & beeping
My range is showing a F9 + beeping. Oven door latch will not allow door to close.
When F9 appeared I pressed CANCEL but, F9 & beeping came back.
I've unplugged the range. I'm desperate ...what's wrong with my range??
I haven't been able to use my range for a week.
Thank you!
  • 2 more comments
  • grnyx3 Mar 24, 2009
    Is there something I can do to make the door latch release & allow the oven door to close? The oven door will not close.
    The strange thing about the whole F9 & beeping is that I wasn't using the oven OR the cleaning feature.
    I appreciate you input....I'm just so desperate to use my stove. Can I still use my burners safely?????
    Can you tell me how to "inspect the door latch"?
    Not that it's important but I'm a senior lady living on SS. Is this something I could fix on my own.
    Thank you....you are so helpful
    Thank you for your hep & patience.
  • Anonymous Mar 21, 2014
    getting f9 code while using range
Anonymous
Level 3:
  • Master 6,784 Answers
  • Posted on Mar 24, 2009
Anonymous
Master
Level 3:
Answers
6784
Questions
Helped
2970668
Points
24702
Hi. this fault code represents a door latch fault. You will need to inspect the door latch components. Once this issue is fixed, it will start to work normally. Its nothing serious like a control board or power supply board. Its juts that the door latch components are malfunctioning.
please rate and god bless..
  • 1 more comment
  • Anonymous Mar 24, 2009
    You should be able to use the burners safely.
    It seems like this may be a mechanism failure. there are a few components that will have to be tested with a multimeter before you will know which component has failed. If you don't own a multimeter, i would call a service tech out for a quick repair visit.
    No problem, glad to help:)
MAYTAG OVEN SHOWING A F9 CODE. I PRESS THE CLEAR BUTTON, AND A FEW SECONDS LETTER THE CODE APPEARS AGAIN. WHAT IS CAUSING THIS CODE. OVEN WAS USED EARLIER AND HEATED JUST FINE.
Hi rosebud1239,
The F9 fault code error description is about the door latch. Please check the door latch components.
Hope it helps.
Thank you for using FixYa.
Got F9 on Amana range model ACS3350 while trying to clean oven. The door is locked and got constant beeping with F9 error code. Powered off oven for 10 minutes and powered on, still getting the door...
Shut off the circuit breaker to it for FIVE minutes, then back on. If the problem persists then do the following:
A latch locks the center top INSIDE of the door during cleaning.
Run a piece of semi-stiff, flat object, like a cardboard strip that is in L shape behind the top lip of the door from RIGHT TO LEFT. You may need to push it along with your finger jambed in there when it reaches the latch. With a little push the latch should open.
Try to run the oven, if F9 shows again, press cancel Oven to quiet it. The Lock state is still in place. Move the latch hook manually all the way to RIGHT. Then shut off the circuit breaker for FIVE minutes, then back on. The oven should work ok.
If this fails again try the five minute shut off with the latch in other starting positions.
If none of these work then the latch mechanism, or it's motor is really broken. Replace or ditch and never buy Amana again!
We have a maytag electric range/oven model #MER5770AAW .after baking some french fries ,with the oven open it made a beep and F9 message came up on the panel.everything still functions ,have hit the...
F9 Door Lock Warning Check door lock circuit or Replace Clock. If clock working don't do that.
ck here for the code.
https://www.repairclinic.com/RepairHelp/FaultCodes/31/Range-Stove-Oven
parts here....
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Range-Stove-Oven/19-4-93082-/new/Maytag-Oven-not-self-cleaning-MER5770AAW
you can call their 800# or use the chat for more info if needed.
first check that the latch is not a 1/4 or so closed.
open and close the latch a few times.
also you can turn off the breaker for a few minutes
and see if it resets the ecm.
Hope this helps a little
Get message F9 on the display, I went to clean the oven in the self cleaning mode, heard the door latch trying to close, then it started beeping and flashing the F9 on the display. I turned off power for...
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
7helpful
2answers
What does F9 mean? Won't allow me to use the oven
F9 -It is a Door latch fault code
Check door latch components.The stove is not detecting a proper door close.Or else there might be some metal blocking the door from closing.It should solve itself in few hours else you might have to replace the door latch system.Good luck with the machine.Please do post comments.Also do rate the solution.Thank you in advance.
16helpful
2answers
How do I clear error beeping (F9) on my Amana gas range
try to hold in on the oven light switch plunger that the door would hit if it was closed properly. what you probably did was to pull the door open while it was trying to lock. once you hold the plunger in, then hit the clean cycle again and then push to cancel button to get the door latch to unlock the door. it may take a minute or two but that should clear up the error code and let you use the oven again.
next time if you push the clean by mistake, just let it go and then when it says "locked" just push the cancel button. it will unlock and be ready to use.
7helpful
3answers
I get failure code F9-3
What a scam by service personnel.
-Simply press "Stop/Clear", then gently push the door handle until "Lock" appears on the screen. Press "Stop/Clear" again and the door unlocks itself!
J. Kalicak
Fridgdaire self cleaning latch
try holding in on the door latch plunger the one that turns the oven light off when you close the door then press start then cancel and inspect the door plunger for any damage
6helpful
6answers
F9 Code after power outage - Model JGR8855ADS
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Generic:
Fault Code Interpretation Components To Check
F-1 Communication error between touch pad and ERC (clock)
Replace the touch pad or clock.
F-2 Oven temperature sensed by electronic control Replace the clock/relay board
F-3 Open oven sensor or harness. Replace the oven sensor
F-4 Shorted oven sensor or harness Replace the oven sensor
F-5 Power to element relay disabled in cook mode Replace the clock/relay board
F-7 Shorted touch pad key sensed for 32 secs. Replace the touch pad/control panel
F-8 Shorted meat probe Replace the probe jack.
F-9 Door lock safety circuit on ERC sensed Replace the door latch assembly
F-C or F-0 Communication error between boards Replace the relay board
Maytag-Maycop-Magic Chef-Jennair-Admiral: Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
Top Maytag Kitchen Ranges Experts
vince
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
