Xerox Phaser 8200 Laser Printer Logo
Posted on Mar 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Phaser 8200 Smears on Linen Paper
We purchased new stationery with a linen finish, and suddenly our Phaser 8200 has a major smearing issue. On a large print job, it will start out fine, but then begin smearing. It literally prints a ghost of the previous page on the following page. Is this a product of the paper type? Is the Phaser 8200 not compatible with linen paper? Any other possible fixes?
Anonymous
Level 2:
Scholar:
  • Expert 141 Answers
  • Posted on Aug 04, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
141
Questions
0
Helped
59359
Points
346
Your maintenance kit is running low on oil and needs to be replaced. Since the image drum is not getting enough lubrication, some of the ink from the previous page is sticking to the drum and carried over onto the next page. Also, try to match the printer paper type to the paper you are using. It will adjust speed, temperature, etc. to optimize print.
1helpful
3answers
What properties do the linen clothes have?
The art of spinning linen yarn has been known for thousands of years, and till now linen fabrics do not lose its relevance in everyday life, fashion, and production. The unique properties of linen fibres make linen clothes not only pleasant and durable but also useful for health.
Miitu specializes in the production of clothing from natural linen. When choosing our products, you can be sure that you give your body health and comfort, and the opportunity to always look beautiful and stylish.
Linen has got bactericidal properties. This means that the pathogenic microflora is killed by contact with linen tissues. Silica (silicon dioxide), contained in flax, suppresses the growth of bacteria that cause fermentation and decay. Regular sleep on linen or wearing linen clothes speeds healing of wounds and acne, sunburn, and wounds in linen bandages are tightened faster. Linen can be ironed with a hot iron and boiled, which makes it possible to provide fabrics with maximum sterilization.
Antifungal properties of flax fibre help to cure fungal diseases. Therefore, linen fibre shoe insoles are used to get rid of the unpleasant odours. A similar effect is obtained by your entire body during sleep on linen bedding sets.
Unpainted linen fabrics are hypoallergenic. When growing flax is much less processed by chemicals than cotton. The high strength of flax fibres does not require manufacturers to use fabric improvers to create protection from shrinkage. Advice to allergy sufferers - choose linen fabrics that are easy to crumple and hard to iron - they do not have chemical treatment from creasing.
Being a natural material, linen fabric is perfectly "breathing", i.e. air flows, steam. It provides optimal ventilation of the skin, helps us regulate heat - when it touches the skin in winter it warms, in summer it removes heat, reducing body temperature. Hygroscopicity, or ability to absorb and evaporate moisture, is higher for flax than for cotton (12 and 8%, respectively). This property is important not only for our summer clothes but also for bed linens and kitchen towels at any time of the year.
Linen does not electrify. Hence, your hair will always look neat, if you wear linen shirts or sleep on linen pillowcases. In addition, the minimum electrification ensures the purity of the fabrics.
More information about linen properties you can find at https://miitu.co.uk/
tip
What Are The Different Types Of Linen Fabrics
Linen fabric (also called weave) is made of fibre from the flax plant. It is most popular and most liked by many users due to its vast benefits such as durability, softness, strength, natural origins, antibacterial and antifungal properties. There is a broad range of different types of linen fabrics which can be identified from each other by the weave patterns and the texture.
Below is a list of the different kinds of the fabrics discussed in details:
Plain-woven linen fabrics
Plain-woven linen is commonly used to make dish towels, cotton towels, and hand towels
Loosely woven linen fabrics
Loosely-woven linen is highly absorbent, but it is the least-durable type of linen fabric
Sheeting linen
Linen apparel is usually made from sheeting linen due to its contexture, soft surface and close weave
Damask linen fabric
https://www.fixya.comdamask-linen-500x500-undefined-undefined-10.jpg
Damask linen isn't designed for everyday use, and it's more common in decorative items
Toweling
This type of linen that are suitable to produce towels. It comes in different sizes and towels that are made can be used for a wide range of purposes
on Jun 25, 2020 • Clothing
Xerox 4620 is printing smears all over the page. I replaced the drum but it is still happening. Not sure what could cause this prblem
ask yourself this . Is the paper warm or hot when it has been printed on ?
check fuser unit .
No heat equals unbonded toner on paper equals smearing of toner on paper.
2answers
Why is my linen dress shiny after ironing at the linen setting?
The fine fibres at the surface of linen stand up like the bristles on a brush. Light coming into the fibres gets trapped. When you iron the linen, you flatten the fine fibres. Incoming light no longer gets trapped in the spaces between the fibres and instead is reflected (bounced back) like on a mirror. That is why linen looks shiny after ironing. To prevent this, use a damp cloth on top of your linen when ironing. This will flatten (iron) the linen material but not compress the fine fibres. Good look.
How to clean phaser 7750
Included general maintenance video and how to clear smears from the paper.
Solution: Remove Print Smears / Printing Fuser Cleaning Pages
7750 Support Knowledge Base Remove Print Smears Fuser Cleaning...
With Troublshooting highlighted on the printer display perform the following steps:
  1. Press OK.
  2. Press the Down Arrow and scroll to Print Quality Problems.
  3. Press OK.
  4. Press the Down Arrow and scroll to Remove Print Smears.
  5. Press OK. The printer will print 5 cleaning pages.
Repeat this process five or six times, to remove stubborn toner buildup from the fuser.
Always make sure you are matching the type of paper loaded in the printer tray(s) to the correct Paper Type front panel setting. When you load a tray with paper, the front panel will ask you to indicate the type of paper you loaded. For correct print quality and printer operation, be sure to set this correctly.
MAINTENANCE:
Phaser 7750 Video Instruction Maintenance for the Printer Phaser
What are table linens?
According to Wikipedia "The collective term "linens" is still often used generically to describe a class of woven and even knitted bed, bath, table and kitchen textiles. The name linens is retained because traditionally, linen was used for many of these items."
Therefore table linens can refer to any tablecloths or napkins, but are so called because they were originally made from linen.
Nov 11, 2013 • Home
I have a problem with ink smearing on Southland fine linen paper on letters I've sent out The letters are folded in three and put in an envelope. The reciepients are recieving the letters with smeared...
Sometimes it's due to low fusing temperature. Certain papers need higher temps. Check the paper supplier or look in the printer setup menus and adjust the paper type to as close as possible to what you have.
1helpful
Blurry Printing
Quite possibly, your Wave Amp board has failed. If so, it is more cost effective to purchase a new printer than to repair yours unless you can find used parts.
Currently, Xerox is offering a trade-up rebate on new solid ink printers.
1helpful
Pinstripes in image after print (phaser 8560)
Appropriate cleaning procedures, as listed in the following tables, should be
performed when specific print-quality or paper transport problems occur.
All cleaning procedures are detailed in the printer’s Phaser 8400 Reference Guide or
the Phaser 8500/8550 User’s Guide.
Light Stripes or Missing Colors
Problem type Solution
Missing or light-colored
stripes on prints.
Select the automated procedure Eliminate Light Stripes from
the Control Panel.
Ink Smears, Oil Spots, or Random Ink Streaks
Ink smears on the front,
back, or edges of a page.
Select the automated procedure Remove Print Smears from
the Control Panel.
Check the maintenance kit for ink and paper-dust build-up on
the wiper blade.
Oil (drum fluid) on top edge
of print.
the Control Panel.
Hope this helps
pdouglasss
2answers
Problem printing in color on Xerox Phaser 8200 from Mac
That actually should make magazine quality color.
What are you experiencing? Do the colors not match? Are there smears or light streaks?
I will gladly work with you to revolve your problem, I just need a frame of reference to start.
Let me know.
You may simply need to download and install a different driver.
They are on www.xerox.com you should be running the PS version of a driver for better graphics.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
