RCA RP3721 Clock Radio Logo
Anonymous Posted on Jun 20, 2013
User manual alarm - RCA RP3721 Clock Radio
A
Anonymous
You can download the user manual at this link;
http://www.manualowl.com/p/RCA/RP3721/Manual/54944
tip
DSC PC1565 Alarm Manual Download
Download DSC PC1565 Alarm Manual
Would you like to review the features of the DSC PC1565 Alarm?
Have you lost your DSC PC1565 Alarm Owners Manual?
Would you like a digital, searchable, pdf version of the DSC PC1565 Alarm Users Guide?
Follow this link (& click FREE) to download a pdf version of the DSC PC1565 Alarm documentation.
I hope that helps.
___________________________________________
tip
I hope that helps.
Where can I find the instructions for the Dreamsky Projection Alarm Clock radio?
https://directbrown.weebly.com/dreamsky-alarm-clock-radio-user-manual-ds201.html#dreamsky-alarm-clock-radio-user-manual-ds201
Sep 29, 2020 • Toys
How do i set the alarm on my ihome alarm dock?
Once the time is correct, users can move on to setting the alarm itself. Many iHome systems come with dual alarms allowing couples to set different times for each person or individuals to designate a weekday and weekend alarm. Each alarm has its own time, wake-to source, and frequency. The process of setting the alarm is the same for both options, the only difference is what button, either 1 or 2, users depress when setting it.
Once ready to set an alarm, users need to push and hold the button down, waiting for the alarm time to appear on the clock's display. From there, the up and down arrows or plus and minus buttons adjust the time backwards or forwards accordingly. Once that is complete, users select the frequency of the alarm by pressing the alarm button again and then opting for 7, 5, or 2, which correlates with all week, weekdays, and weekends respectively.
The final part to set is the wake source of the alarm. Users press alarm buttons one more time, and then use the same directional buttons to choose from iPhone and iPad on some models, radio, buzzer, or playlist. If users choose playlist, they must also setup a playlist within their Apple device titled iHome.
Because frequency is part of the alarm setting process, there is no need to turn on the iHome alarm manually as one would do with a normal alarm clock. However, users can check to see if the alarm is active by looking at the screen of the clock for the earliest alarm time, displayed on its lower part.
In the mornings, when the alarm sounds, users have two options: Snooze and disarm. The disarm process turns off the alarm until the next day in its frequency chain. Users disarm the alarm by pressing the power button. On the other hand, users must manually program the snooze button. Users do this by pressing and holding the snooze button and then toggling to the desired snooze time, generally between one and 29 minutes. Once this is set, users simply press the snooze button in the mornings to delay the replay of the alarm for that amount of time.
2helpful
2answers
How do I reset the Master code in DAS NX-4--8 alarm system when the existing Master Code is not known ?
Be sure you understand the difference between a master code and the technician code. A master code lets you program other codes (and do some other harmless stuff). The technician code lets you do anything in the panel. If no master code is known you will need to default the panel. Do that by turning off power and disconnecting the battery. Reconnect the battery or plug pack and within 10 seconds enter 971300 on the code pad. That will wipe the eeprom back to factory defaults, and reinstate user 1 as a master code with a value of 1234. Don't even think of doing any of this without an INSTALLER manual. (Not the same thing as the USER manual). Better still, get an alarm tech familiar with DAS or CADDX products to program it for you. Worth every penny. After that you can add/delete users with your own master code using the much simpler User manual. Any code can be set to be a master code (that is you can have more than one master code)
3helpful
3answers
I can't find the user's manual for this watch: Armitron Sport 40/8125BLK Watch
You can download the user manual for your watch from this link(http://www.watchesmanuals.com/Armitron/Armitron-Sport-40-8125BLK-Watch.htm)
2answers
Hi i have a toad A101cl alarm in my car.. it was fitted before i bought the car so i have no user manual or pin-codes etc etc. i had only 1 set of remote keys but now they have been damaged and i cant...
heres the user manuel file:///C:/Users/Administrator/Desktop/toad-a51s-a101-a201.pdf
alternitivly go to http://abacuscaralarms.co.uk/members
and download from there
hope i was helpfull
3helpful
User manual for omega freedom 150 car alarm
I'm assuming you need the user manual here? here is a link:
http://www.omegarep.com/All%20PDF/Free-150%20Manual.pdf
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
