F-1 Code, what does it mean? And, how do you stop the beeping, on the Magic Chef Stove?
SOURCE: magic chef range
f1 is the code for a failed clock most of the times you must replace the clock most of them have a five year warrenty check your owners manuel for warrenty info
SOURCE: one of the burners won't light.
check all wires to burner and switch. If they are good .....burner burnt out or switch no good.
SOURCE: Magic Chef propane in 90 Terry 5th Wheel
unfortunately the model plate for these
was usually mounted on the the drop wall
or were paper on the inside right corner
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
F1 for Magic Chef means there is a problem with the control board or the touch pad to the board. I would need the entire model # on sticker on the oven to see what parts are on this one. If the touch pad is separate it will have a ribbon that goes from it to the board. Unplug that ribbon, if the code goes away then the touchpad is the problem. If the code stays with the ribbon unplugged then the control board is bad. Make sure power is off to unit when touching anything!
