Question about Aqua Hardware & Accessories
Melnor 4 zone aqua timer dosent follow program
My aqua timer is set to water each zone in one hour increments 1:00 2:00 3:00 and 4:00, the trouble is that it will turn one of the zones on at 11:00, which zone appears to be random. Time of day and zone times have been checked a number of times and are set correct.
Posted by Tom Porter on
Gene Haynes
  • Aqua Master
  • 5,391 Answers
Water timers and Melnor timers last a year or two. They come with 1 year warranty for defects in workmanship.
Change batteries, reset timer if there is a reset protocol, buy another timer. Melnor, Orbit, are major brands. Gardena is not supported. Yardworks repackages other brands.
Copy following link for all watering and irrigation timers on market, with links to manuals for each brand:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Add a comment and say what you find.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Jun 20, 2013
4 Related Answers
manhandy
paul sandouk
  • 146 Answers
SOURCE: Can't correct the current time in the Melnor 6
go to there web Site
Posted on Jul 13, 2009
Gale Todd
  • 1116 Answers
SOURCE: I have a raindrip 2
You can download your instructions here:
R673CT Digital Water Timer Installation Manual
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Posted on Jun 09, 2011
Gene Haynes
  • 5391 Answers
SOURCE: Problem programming timer settings. Is it supposed to be random or continuous?
1) Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#50006
2) How to set analog timers by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
3) 50001 timer is not random vacation timer like the 50003.
50000 series timers by Woods have 1 year limited warranty, and they are a new design released this year. However the analog timer design has been around for many years.
4) If timer is acting randomly, then
a) timer is defective,
b) the override switch is not fully positioned at 'timer on,'
c) segments are not lifted fully in position,
5) ... other more remote causes: outlet might not test 80% rated voltage?, outlet might have reversed polarity?
5) Try timer on different outlet with different light.
6) As the timer dial rotates, the segments push small lever, and the lever moves switch that turns lights on-off. I suppose if this lever was broken or switch was broken, then timer would act more randomly.
Posted on Dec 06, 2012
Gene Haynes
  • 5391 Answers
SOURCE: How to set time on Yardworks two zone water timer
Copy following link to access manuals for each brand of water timer on market 2013:
Yardworks does not have website, manuals or warranty claim procedure.
Instead, yardworks repackages other brands of timer, generally water timers, such as orbit or melnor and raindrip. And sometimes repackages other brands of outdoor timers.
Recommend folks stay away from timer-repackagers such as Yardworks, Timex, First Alert, and buy brand names that have clear customer resources.
Posted on Jun 05, 2013
How to fix a melnor 4 zone digital timer with stuck valves?
bleed the air out of each valve then re tighten bleed screw. if still stuck open then buy new diaphrams
Dec 13, 2015 | Melnor 3280 Digital Aqua Timer Watering...
Melnor water timer
Melnor is major water timer company, and not off-brand. However, water timers last a couple years, or less, sometimes they last long time but that is not often.
If not drained completely of water, they will break when water freezes.
Copy following link to identify all water timers on market today:
Most timers have 1 year limited warranty for defects in workmanship.
Jun 05, 2013 | Hardware & Accessories
Timer 3018AR manual
Timer could be Melnor 3015 or Melnor 3018
Copy following links to download possible manuals:
http://waterheatertimer.org/pdf/melnor-aqua-timer-3015-B.pdf
http://waterheatertimer.org/pdf/melnor-aqua-timer-3015.pdf
http://waterheatertimer.org/pdf/Melnor-3018.pdf
Jun 05, 2012 | Hardware & Accessories
Regarding the Vigoro Electronic Water Timer, Model 196 036: How do I program the timer to water every day, in the early a.m., then in the evening? Is the greatest hourly spread per day 12 hrs.? In...
I think you almost have it right, you can program how many hours apart.
4=6 x per day
6=4 x per day
8=3 x per day
12= 2 x per day
24=1 x per day
Then you set how long you want it to be on, but that can't exceed your hour setting. I believe these are the same timers as Melnor. You can go to their web site for manuals. http://www.melnor.com/instructions.php. If you really want exact timing, I'd get a quality electric timer, and then buy a electric valve such as you'd use for a sprinkler system.
Jul 13, 2010 | Garden
Can it be set to water every other day
Assuming that your model number is 3018 you just need to keep cycling through the frequency options by pressing "change". The hourly options end with "h" and the day options end with "d". So "2d" means every other day. Press "accept" when you come to "2d".
May 29, 2009 | Aqua Hardware & Accessories
Hardware & Accessories Logo
555 people viewed this question
Top Aqua Hardware & Accessories Experts
Gene Haynes
Tom Chichester
Are you an Aqua Hardware and Accessory Expert? Answer questions, earn points and help others
