Hamilton Beach 1.1-cu ft Microwave Oven, White Logo
Question about Hamilton Beach 1.1-cu ft Microwave Oven, White
MICROWAVE METAL PLATE CRACKED
The metal plate on the wall of my microwave cracked with a loud pop! Is the microwave toast, or is it safe to continue using?
Harjeet Singh
    New Friend:
  • 109 Answers
It is megnatron plate which broke. You can replace that plate yourself . Also can can work without if safely.
Posted on Jun 20, 2013
1helpful
I have a Samsung ME18H704SFS- overheating help.
It will be fine. They aren't made for sustained cooking on high power. Popcorn is dry but oiled, so it gets very hot and burns. You can use the glass carousel plate or replace it. Depending how big the crack is, any water in the crack will finish it off. A new glass tray is $57. A new Microwave the same is $319. Samsung are one of the better makes.
https://www.google.com/search?q=samsung+me18h704sfs+replacement+glass+plate
Massive sparking and noisy when switched on to heat
There are 2 things that cause the massive sparking:
1. you placed inside the microwave oven a metal plate or one with silvery or golden drawings;
2. the mica sheet that covers the magnetron window is compromised (has holes, it is cracked) or it is covered with burnt (carbonised) food.
You have to carefully inspect the mica sheet and wash or replace it, if necessary. Hope that helps.
Regards,
Dan
I can't figure out how to get my older roper microwave off the wall
If there is a grill above the door, remove it. There will be two long screws that attach the unit to a metal plate. The metal plate is bolted to the wall. Once you loosen the long screws, the unit will tilt down and come off the wall.
3helpful
5 yr old microwave has worked perfectly - until now. Put small amount of food on a safe plate in for 45 seconds. Plate suddenly cracked, was extremely hot - and food wasn't even warmed.
The plate wasn't microwave safe or has a crack in it that had moisture in it to cause it to split.
A new pyrex type glass plate will get it going again.
My microwave was making a popping sound. then while i was nuking some popcorn, i heard a loud bang. when i opened the microwave, i saw that the glass turntable plate on the inside had split into two...
What usually happens to make the plate break or shatter is heat build up in one place, caused by spillage of food stuffs that have "welded" themselves to the plate or a scratch on the plate allowing water to enter and when it gets hot explodes the plate.
There, from what you have explained and the information you have supplied, no reason to doubt the machine. A new plate and it should work again with no problem.
Hope that puts your mind at rest.
4helpful
The White enamel/paint in the interior of the microwave, by the base & back wall seem has peeled off - about 2 inches. I see unpainted metal & I am concerned. How do you fix this problem and is it...
The area will first have to be sanded smooth and cleaned and dried thoroughly.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-WELD to patch the crack or hole.
Once that dries thoroughly, you can sand it very smooth.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Sparks from inside the microwave
How old is the unit?
Is the 'Plate' clean?
Larry Hanson
18helpful
2answers
Burnt hole in metal plate inside microwave oven
Ok stop useing oven and unplug! THIS CAN BE FIXED!!! Go to a home improvment store and buy a small bottle of white liquid enamal....Clean up the area that is missing and flakeing and then apply the enamel over the hole and let dry overnight! now that the exposed metal is covered back up it is safe to use and will not spark or cause any more soot!
PLEASE rate my response to your question!
THANK YOU!
Top Hamilton Beach Microwave Ovens Experts
Marvin
Marvin
john h
Are you a Hamilton Beach Microwave Oven Expert? Answer questions, earn points and help others
