The accuator that controls air flow to the fridge was in the closed position,
I pushed the damper open and replaced the ducting that runs up the back wall but still no air flow, freezer however is remaining at -6.
is there another air deflection in the freezer ?
Air from freezer could also be restricted. Need you to find me the correct model number.
Look at following areas for the model number
Whirlpool side-by-side. Freezer gets plenty cold, but fridge side is only "cool". The vent allowing air from the freezer side into the fridge side is wide open (I dis-assembled the slider mechanism to check it is fully open). But the compressor is off suggesting the freezer thinks he's cold enough.
Some air flow comes through the vent when the compressor is running but not very much.....vent blocked inside the dividing wall?
