Re: Cables to link LG Plasma with Panasonic around sound...
I would have to see the sound system you are hooking into. The way to get audio is to hook it direct from your cable/satellite box to the stereo. There is no need to go to the TV for audio.
Have you tried different HDMI cables?
Have you tried switching the ends around?
Are you sure you changed your TV inputs to the correct one?
Not all LG TV's will sense an HDMI connection and offer to switch to the new input.
I know it sounds ridiculous but I had an HDMI Cable break just sitting there. Also they now have HDMI Cable that are Unidirectional, you can plug them in backwards.
Move the insulated cables for the bose away from the cables to the tv. Or go buy monster cables for the TV so there wont be interference. Sounds like power cables are interupting the picture.
Tries tv unplug,replug it back like about hour later.For the tv do a resetting itself,take out the tv HDMI cable out the old HDMI hub port try plug it into another tv HDMI hub port.Should work now,still have same problems,probally needed a new HDMI cable replacement,the old HDMI cable is worn out or shorted out.
There are a couple of different ways you could go with this. Your Panasonic SCP-T480 has an HDMI and a digital optical port HDMI carries audio and video signal so, it would be your easiest/best bet. Digital Optical provdes sound only but, provides as good sound quality as HDMI but, no video To use the digital optical for sound you would also have a composite(RCA) cable to gain your video.
You can buy an HDMI to DVI adapter (around 20$) to connect your HDMI computer cable to your TV. You will need separates audios cables, right and left, to bring the sound to the TV.
switch the HDMI cable to another HDMI port (if available). or use and AVI/COMPONENT to make sure the device (HOME THEATHER) is working fine. Try also another HDMI cable or hook another device into it to see how it works. If you determine the HDMI port in not working properly, then your Mainboard is damaged and need to be replaced, try EBAY for a general
picture of prices but you will need your product code wich is located
in the back of the TV next to serial number.
You just need to connect an Audio Out port on the back of your TV to an Audio In port on the back of your JVC box. See what connections you have, I'm sure there are lots of options for you such as HDMI or just normal 2-cord audio cables.
My best advice is to do a factory reset on the system and then set it up again like you did when you first installed it. Unless your daughter physically damaged cables, the system should work OK. It's no use trying to work out what she disconnected as that will take even longer than a factory reset.
what you need to do is look at you HD DVR box and see if you have an "optical" port on the back then check and make sure your home theater box has an "optical" port. if they do all you have to do is go to radio shack and pick up an audio OPTICAL cable and go between your HD DVR and your home theater box.
You did not list which console you have and what type of cables it has.
Looks like your plasma has: 1 component 1 composite 1 VGA 1 S-Video
If this is an xbox360 or PS3 then you will want to use the component connection, but this one is already used by the cable tuner. Don't worry there is a solution. The xbox360 and ps3 output a higher resolution that your plasma can handle, so use the component with those systems.
If it is an older console, predating the xbox360, then use the composite or S-video connections.
Since you are short on video inputs, you might need a video switch. A switch with both component and S-video connections for future add-ons.
You can find them all over the web, or your local video store like walmart and best buy. Here is a switch i found on ebay that should work: http://tinyurl.com/3aoev9
here is the ebay search i used: http://tinyurl.com/2ograc
Make sure you buy extra cables, most of these boxes do not come with cables, so buy what you need.
I prefer video switches that don't require a power outlet, but it's your choice. Some of the powered switches, have remotes for the lazy people, but I don't need anymore remotes on my table, keep that in mind.
