Akai PDP42Z5TA 42 in. Plasma Television Logo
Posted on Mar 24, 2009
Tv only has top right corner showing picture
The tv was working perfectly fine yesterday and today the picture is only in the top right corner (partial picture). The rest of the screen is black. It is an Akai plasma tv. The problem is not related to anything that it is connected to. Is there anything that could work to fix it?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 21, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
513
Points
Hello the picture was good 2 days ago.I took a picture of the plasma ..could please help me with some ideas...thank you..
  • Anonymous May 21, 2010
    looking for help please
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
1helpful
2answers
JVC HD56G647 TV was working fine. Made a popping noise and now we have no picture or sound. Both lights on the front are flashing in unison. Help!
The popping noise is not a good sign. You definitely have a shorted horizontal IC and probably a bad flyback transformer. You will find several bad capacitors that contributed to this problem. The cost of repair will be more than your depreciated TV is worth. Sorry..look for a new one. Thanks for asking and show a few hands of support!
1helpful
One day old samsung 40LC530 LCD tv shows a dark patched screen
that is a factory defect you call the dealer for the warranty.the defective part of your tv is the inverter board.this board supplies high voltage supply to the backlight cold cathode flourescent lamp.This lamp is the one illuminating the screen of the tv..the lamp is installed at the top and bottom of the screen thats why the center of the tv is dark because the lamp does not lit well..tnx
hope i help you
please rate my help..
Not Printing anything today. Ink cartridges show
Uninstall than reinstall the software. This has worked for me in the past.
Samsung LCD -no picture/sound from any input source-Cable,DVD,PS3
Use the menu button in the front screen of your tv.Maybe your remote control need a battery.
Corner tints and white lines
it can be a picture tube problem. moreover, check if your tv is dusty inside it . clear it with blower and try again.
regards,
2helpful
2answers
Black screen
whats up with blackscreen?
Vertical colored lines on top and bottom of screen
Definately a video processing problem and it may need a logic board it is called. Does the set work fine if you feed component into set to bypass all that? Let me know. GURU JAY
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
