Question about RTO Church 1898 Purite Personal Cleansing Spa Toilet Seat White
Seat is flashing not getting hot - RTO Church 1898 Purite Personal Cleansing Spa Toilet Seat White
The speed lights keep flashing. It still moves.
The speed light flashing usually indicate that the chair is in "Limp Mode" This could be either the motor is getting too hot or the chair has a lift on the seat. If the chair runs fine for a while and then this condition appears, you may have a bad motor or a brake dragging causing the motor to get hot. the controller will allow less power to the motors to help it cool down and still keep you mobile. If you have a lift on the chair that raises up the chair, you will have to lower the chair down to gain the full power back. If neither one of these solutions are the problem, then you will need a Tech to come out and look at the problem. you may have a more serious problem that a tech can troubleshoot.
May 11, 2015 | Pride Jazzy 1103 Ultra Standard Power...
CAUSE OF FLASHING O/D LIGHT AND HARD START AND SPEEDOMETER ERRATIC
Get it scanned for errors. The VSS or the speed sender unit may be damaged or not seated/fitted correctly.
May 08, 2014 | 1998 Kia Sephia
Flash does not trigger
To make a guess as to what is occurring you have not presented enough information. So here are some things to try:
  • Make sure the flash is seated solidly on the camera. That is usually the issue.
  • With flash off the camera look at the shoe mount. Check the locking lever making sure when turned the center pin extends and retracts.
  • Sometimes the center pin does not engage the hotshoe
  • Clean both the bottom of the flash is clean and also the camera hot shoe.
Oct 16, 2013 | Nikon Speedlight SB-600 TTL Flash
Part of seat gets very hot with seat warmer
So you have real toasty buns, eh? I would unplug the seat warmer for now.. Repair it before it starts a fire in your seat cushion, one of the warming elements has a problem. It will just have to be examined. Check with ford, maybe they have a solution that doesn't involve removing seat and tearing it apart. Sit lightly, wow, talk about being in the hot seat!
Nov 25, 2012 | 2008 Ford Fusion 3.0
My Pentax K1000 won't flash when taking the picture
Questions: is the flash fully seated on the hot shoe, are the batteries in the flash good, finally does the flash fire on another camera. My K1000 would not fire any flash on the hotshoe nor using the PC plug it needed a CLA.
Feb 17, 2012 | Pentax K1000 35mm SLR Camera
I have cleaned the toilet seat in hot water and the plastic glued stoppers for the seat have fallen off and the glue has become hard. Where do I get new stoppers from.
Hi seacenter30
Why buy new seat stoppers when all they need is just re-glueing.
Get yourself a cheap hot glue gun (HomeDepot,Lowes,WalMart,etc) and a couple of hot glue sticks and apply the hot glue to the rubber/plastic stoppers and hold them into position on the toilet seat lid till the glue sets, just takes about 20 seconds...
Then the toilet seat will be good to go again...pardon my pun...:-)
Please take time to rate me thumbs up
Sep 14, 2011 | Prestige Home
Our little gourmet dual hot/cold faucet has just started to gurgle out hot steaming water all day without use. The complete faucet is burning hot. Unit is 4 years old and used frequently.
having hot water trickle out all day will make the whole unit hot,, to the touch,, what you need to do , is turn off both the water supplys under the sink,, then remove the handle by removing the hold down screw,, after that , remove the hot water valve,, Just remove the nut that's on the outside of the fixture, what your going to find is at the end of that valve, is a washer,, made of hard rubber,, that needs replacing,, but also, inside of the fixture is a washer seat, its either brass or stainless steel,, that takes a seat tool wrench to remove that ,, but to make sure its repaired completely, both the washer and seat need to be replaced, seat tools are pretty inexpensive at Lowes , or Home depot,, and thats where you can get the parts you need also,, be sure and compare the old parts with the new, so take them with you when you go, most hardware stores that have plumbing supplies will have what you need, the seat just unscrews , but they can be a little tough,, if you decide to get a seat tool, they have straight ones and 90 degree ones ,, the straight ones you'll need a wrench to assist turning in the removal and install,
Aug 26, 2011 | Mountain Plumbing Products Little Gourmet...
I have a 2005 gmc envoy and the driver seat gets hot
There may be a stuck relay Stuck in the "On" position. A relay is a remote switch that does the heavier work of a smaller or more delicate switch. It is probably under the seat but if you have "memory" seats that move the power seats back and forth it is probably the control box causing the problem. It has relays inside it.
Jun 30, 2009 | 2002 GMC Envoy
Heated seat
The heated seat element burned out.
Dec 21, 2008 | 1997 Pontiac Sunfire
Instrument cluster damaged after battery shorted out.
4 resistors on the back of cluster bad get them at radio shack.
Dec 14, 2008 | 1998 Buick Regal
RTO Church 1898 Purite Personal Cleansing Spa Toilet Seat White Logo
57 people viewed this question
Top RTO Home Experts
john h
Tom Chichester
Are you a RTO Home Expert? Answer questions, earn points and help others
