Question about Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera
PowerShot SD630 lens stuck out, says lens error, restart camera
Lens won't retract, wont, take pictures, won't review pictures. Pushing On/Off button just shows message on LCD: "lens error, restart camera".
Posted by herny_hagan on
  • Anonymous Apr 08, 2009
    can anyone post a pdf of service specs so i can open the camera safely to put the lens back on track?
  • Anonymous May 07, 2009
    lens sounds like the gears are slipping when the camera tries to focus or adjust the lens
j_v_roden
  • 32 Answers
I've had similar problems with various versions of this camera. Here's the fix, if all else fails. These are step-by-step instructions to take apart and fix the camera's lens error. http://johnsmouth.wordpress.com/2010/12/01/lens-error/
Posted on Dec 02, 2010
Nate Stansfield
  • 11,896 Answers
YOUR CAMERA MUST HAVE VERY NEW BATTERIES AND/OR FULLY CHARGED. CAMERAS ACT REALLY GOOFY WHEN THEY HIT QUARTER POWER. ALSO TRY CLEANING AROUND ZOOM
Posted on Mar 31, 2009
  • Nate Stansfield
    Nate Stansfield Mar 31, 2009
    IF YOU ARE USING A MEMORY CARD, YOU CAN TRY REMOVING IT AND THEN USING THE CAMERA. SOMETIMES THE CARDS INTERFERE WITH THE CAMERAS FUNCTIONS.
When i turn on my camera it beeps and the screem goes black saying.... Lens Error, Restart Camera.. how do i fix this?
Had this happen with the lens stuck in the retracted position. Rapped the camera on my palm to jostle the lens a bit, turned it on and back to normal.
Apr 03, 2010 | Canon PowerShot SD630 Digital ELPH / IXUS...
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens error, restart camera
Try to unstick the lens by gently pushing it in or pulling it out a little bit. IF that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
Dec 08, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon sd630 dead
Lens is defective, change the lens
Nov 01, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
the beeping sounds means that your camera lens is stuck. contact the manufacturer (canon), for a possible solution...or they can even send u a new one. My friend dropped her SD630 and had the same problem...she contacted canon, and sent in her camera to be fixed, but it wasn't fixable, so canon sent her a brand new camera. hope this helps.
Jun 14, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
I need HELP
Dear ashlyw:
A lens error due to impact damage most often requires service.
If you get an E18 message or a "lens error restart camera" message on your LCD screen and you restart the camera several times to no avail, you will almost certainly need to call Canon Tech Support at 1-800-828-4040 and have it sent in for service as there is little or nothing you can do to resolve the issue.
Hope this helps.
Sincerely,
HeavyDLB
Jun 02, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD630 LENS WONT CLOSE,LENS ERROR RESTART CAMERA
I have the same problem. How do you restart the camera. I have pulled the battery and SD card, but can't get to a menu screen to restart to camera.
Apr 16, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Dropped camera lightly, lens wont retract
my acm dropped and i messed up the lsenes it wont go in please help me how can i fix it my self?
Nov 03, 2007 | Canon PowerShot A540 Digital Camera
Cannon Power shot SD630 Lens Problem
I had the same problem, tried different things but this is what worked.
I put the camera flat on its "back" (screen down, lens up). Looking down at the lens I could see that it was slightly off center. I pushed the lens towards the center and down, forcing it to close. Once it was centered I was able to turn it on and off no problem.
Sep 30, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon PowerShot SD630 Digital ELPH / IXUS 65 Digital Camera Logo
947 people viewed this question
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
