Dell OptiPlex 210L PC Desktop Logo
Anonymous Posted on Jun 20, 2013
Continuous beeping The light turn orange
Lars Olsson
Level 3:
Brigadier General:
  • Dell Master 3,400 Answers
  • Posted on Jun 20, 2013
Lars Olsson
Dell Master
Level 3:
Brigadier General:
Answers
3400
Questions
Helped
1048271
Points
10330
Dell 1555 Studio laptop won't power up. After the power cord is plugged in, the LED light on the side blinks white once and orange four times. What could be causing it and how can it be remedi
have you tried a different power source or power supply ,maybe you can borrow one from a friend and try and if that don't work you might have to take it apart and see if your power cable is seated properly in the motherboard
I have an F&P top-loading machine, about 3 years old. There is no model number on the machine fascia. The problem occurs after startup. It starts to fill with water and then it beeps. There are two...
Hi Grant, just read your posting.The model number is on a sticker at the back of the machine, top left.Now the lights that come on when it is beeping will be in a row of 8 lights.Starting from the left to right which ones are lit when the machine beeps,Is it the 2nd and 5th or the 1st and 7th ---etc---?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
2answers
In My APC UPS, continuous beep sound is coming with simultaneous Orange and Green lights are appearing
Unfortunately that signals an internal fault with the UPS and it requires immediate replacement / repair. Do not continue to use the UPS at all.
1helpful
2answers
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • 0helpful
    Ive got a long continual beep and it emits orange light from the front and back of the computer how am i to fix it?
    Turn the computer off.
    Unplug the power cable.
    Remove the video card.
    Remove the RAM.
    Re-insert the video-card, ensuring that it is "seated" properly.
    Do NOT re-install the RAM, just yet.
    Connect the power cable.
    Turn the computer on.
    If you get a different "beep", the lack of RAM is the problem.
    If you get the same "beep", the video-card is the problem.
    Disconnect the power-cable.
    Re-install one stick of RAM (two if it is RAMBUS/RDRAM).
    Reconnect the power-cable.
    If it beeps "normally", then the not-yet-installed RAM is the problem.
    If it still "long-beeps", turn the computer off, disconnect the power-cable, and remove the RAM, and insert the "other" stick/pair of RAM.
    Reconnect and start it up.
    If still a problem, change the video-card.
    1helpful
    BJC55 Printer not printing
    There are some possibilities due to the above phenomena. Let's discuss about it:
    1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
    2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
    3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
    Hope these help.
    YBC (/\)
    Camera won't turn on, just beeps
    first check the battery... charge or replace it... else reset the camera or repair
    Ga-k8nxp-sli problem
    you have a hardware fault try removing 1 set of memory test if not work try different video card suspect one or other wrong
    3 beeps
    Got to this Cannon site:
    http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=230&modelid=7998#
    Find: Search Our KnowledgeBase - Type in: three beeps.
    Look below: Search Results for three beeps.
    Click No# 1 Error Codes - Beeping and Flashing Lights
    Scroll down the page and match the 3 beeps and the color
    Below that is the fix
    Please vote. Happy Holidays!
    Grand Canyon Tech
    Grand Canyon Tech
    SmartAviator
    SmartAviator
