When the yahoo messenger is double click the icon get busy foe about few seconds and no operation or messenger window is not opening.when we see in task manager process tab the yahoo messenger is running.Please help me to resolve the problem foe me help me soon.
At first you should find the source of problem, yahoo messenger? OS? or maybe Server!
But I think it comes from your yahoo messenger, please remove and then re-install your yahoo messenger, if problem stay, check the other version of yahoo messenger.
By the way above, I think your problem will solve.
Other scenario:
Maybe you installed a software that make a conflict with your yahoo messenger and let it not to open, check that software! Remove the softwares that you installed these days.
Maybe your OS damaged, you know that if you run OS for too long times, it will dameged and you need to re-install it and fix the problems.So, if none of two ways above can't solve your problem, re-install your OS, but before that read the following note:
You can use some Optimize softwares for fix and make your OS optimize.like Symbian products.they could find the problem and fix them.So if this way couldn't help you either I suggest you to re-install the OS.
NOTE: Check your firewall, if you have firewall on your computer disable it and check runing the yahoo messenger maybe your firewall bothers your yahoo messenger!
Good luck
