What is the correct ohms rating to calibrate the Vestax PDX d3S turntable? I would send it for a service however I cannot afford, and it looks straightforward for a Technics 1200/1210. Thank you
SOURCE: Pitch control center moved
Hello, Mr. Dixon.
I had the same problem and i decided it whit this procedure:
1. Restoring Factory Default Settings
2. Set the PITCH Slider to the center ( 0 ) position.
3. With the CDX-05 in the start mode displaying “no Disk” hold down EJECT and TIME/ENTER and press FILTER. The TEMP display in the LCD reads 0.0 and the procedure is complete.
Peter Petrov
SOURCE: Vestax Handy Trax
Since the Handy Trax Comes with a Sapphire needle, upgrading to a diamong one will give a better sound http://www.turntablelab.com/dj_equipment/1/131/4962.html
SOURCE: i carnt remove the turntable platter can anyone help
The platter needs a drop of oil as the platter and motor shaft is a machined fit, Via brass upside down v as the platter will be reversed ie: a A WITH NO LINE . You can place two plastic wedge shaped blocks ,one on each side of the platter with even pressure and work up.
SOURCE: hi, have been given a vestax pdx 2300 turntable
Is there a speed control switch? UNPLUG and try spraying contact cleaner into the speed control. IF that doesn't solve it, then back to the manufacturer.
SOURCE: my turntable keeps skiping for no reason, no
What is the weight on the stylus? Flip the protective shield
down to protect the stylus if available. Tare the tone arm (adjust the counterweight
on the back of the arm until the arm floats perfectly level), then hold the
counterweight and turn the dial markings to read zero. If you cannot find the recommended
mass for the stylus you can use the average weight of 3g. Verify your tone arm
is still floating in the center and the arm is perfectly level. Turn the
counterweight until the dial indicates the specified weight of the cartridge
manufacture specification sheet or you can set it for 3g if you do not have the
specification
sheet.
