Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
10657 error code
When i want  to open my time machine to view my backup folder  ex:as i photo it give me this message 10657 . so all my backup folder with time machine can not open  i will appreciate your help
Posted by gambller on
  • KILTY74 Apr 26, 2009
    When I bought this back up drive I thought that I would be able to open all of the files backed up on it, but all I get is the error 10657 message. Very frustrating as I cannot tell if the backup worked and cannot get to the files.  According to the above posting if my Macbook Pro crashed I would have to purchase another before I could recover any files -- not what I was looking for in a back up system!
JDTec
  • Apple Master
  • 4,338 Answers
I got the solution to this problem at the Genius Bar.
As they explained it, Time Machine is software that saves files on the backup drive in a format that can only be read by Time Machine. So, when you open Time Machine, you can click on any file and it will open.
If you try to open a file directly from the backup drive, it needs a program to open it, and if Time Machine is not open, you get the error message.
If your computer crashes, when you get it fixed (or get a new Mac)and when you connect the backup drive, Time Machine will recognize it, will ask you if you want to associate it with your computer, and when you say yes, all your backed-up files are availabel and copied back into the computer.
Genius Bar:
http://www.apple.com/retail/geniusbar/
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Mar 24, 2009
How do i view the backup from my previous computer ? i can see the photos from my iphone and one pdf file, the files from the computer are "protected"
Eortiz, did you try to read the files with a windows PC? Because when you connect the external drive to a PC you should be able to view the files and even be able to change the attributes like read only and hidden.
May 12, 2014 | Hitachi Touro Mobile Portable External 1...
Does my Maxtor back up my iphotos?
Run a time machine backup. Then the easiest way would be to find a photo that you are willing to delete in iPhoto.
Jot down the name of the photo file, delete it. Then empty the trash.
Then go into time machine, try to search for that file, when you locate it, restore it. If you can then there is probably a good chance that you time machine backup is good.
To be on the safe side why not create a manual backup.
You'll find the iPhoto Library at:
/Users/username/Pictures
"username" will be your name that appears when you login to the computer.
  1. To get there, double-click the icon for your hard drive to open it, then double-click the Users folder. Double-click your Home folder, which is identified by a house icon and your username, and then double-click the Pictures folder to open it.
        1. Inside the Pictures folder you'll see a file called iPhoto Library. Copy the iPhoto Library file to a location other than your hard drive, such as your Maxtor external hard drive.
Feb 12, 2014 | Apple MacBook Pro Laptop Computer with...
NEED TO KNOW HOW I CAN PREVENT BACKUP FILES FROM GOING INTO MY RECOVERY(D), AND FILLING IT UP. I AM RECEIVING MESSAGE THAT I HAVE LOW DISK SPACE IN RECOVERY DISK. HOW DO I FREE UP THIS SPACE, AND HOW
Are you sure the files are going in there? Many times the manufacturers only allocate the size that they need partitioned on that drive. I have seen many cases where that drive is full from factory and people always get that message.
  1. Click Start c01508537.gif and right-click Computer .
  2. Select Properties .
  3. Click System Protection from the left side of the Window.
  4. In the section "Automatic restore points", remove the selection next to the D: drive, and then click OK . If the D: drive was not selected, close this window. Figure 3: System Protection tab with D: drive unselected
  5. Right-click Start Explore All Users .
  6. Before you can remove the backup files and folders, you need to be able to view hidden system files as follows:
    1. From the explorer window press the Alt key on the keyboard to make the menu bar appear in the window.
    2. From the file menu, click Tools , and then select Folder Options .
    3. Select the View tab.
    4. Select Show hidden files and folders , remove the selection from Hide protected operating system files and then click OK .
  7. From the Folder Options window in explorer, double-click Recovery (D:) .
  8. If a Window opens stating "You don't currently have permission to access this folder" opens. Click Continue .
  9. If you previously copied or created any files into Recovery (D:) and you want to keep them, copy them to another drive - such as the C: drive.
  10. Find and delete any files that you previously copied onto the Recovery (D:) drive.
    CAUTION:Do not delete any files that are associated to recovery! Do not delete the items RECOVERY, $RECYCLE.BIN, boot, hp, PC-Doctor, pcdr, or PRELOAD! Doing so can prevent a future system recovery from the hard drive. If you are not sure, do not delete the file.
    Press Shift + Delete to permanently remove the files.
    To delete files created from MS Backup (MS Backup files are not recovery files), find and delete the folder with the same name as the computer name in the Recovery (D:) partition. For example if the computer name is BOB-PC, the folder containing the backup files would be named BOB-PC and would be deleted.
  11. Several confirmation windows open. Click Continue , and Yes until the folder is deleted.
  12. To set Windows Folder Options back to their original setting as follows:
    1. From the explorer window press Alt to view the file menu.
    2. Click Tools , and then select Folder Options .
    3. Select do not show hidden files and folders and select Hide protected operating system files .
    4. Click OK .
  13. Close explorer. The Out of Disk Space errors should no longer appear. If you would like to use the Microsoft Backup Tool again, open it and select a different external backup device to store the backup files on.
Aug 17, 2012 | HEWLETT-PACKARD Computers & Internet
How do i delete only selected message recipeint or call from the log. How do i move any received file into any folder in memory card. Not in memory card..but a folder in memory card
Hi, you can delete selected message recipient by using Conversation View in Nokia X3. Please open Messages menu and select Conversation view, now select option on any message recipient then select Delete Conversation to delete the messages sent by a particular recipient. You can delete Calls from the log by opening Log Menu and selecting "Clear Log lists". You cannot move any Messages directly to the Memory Card or to a folder in Memory Card. However you can backup all Messages, Contacts, Calendar, Notes...etc to the Memory Card by going>Menu>Settings>Sync & backup> Create backup option. This will create backup on which you select like Messages, Contacts...etc to the Memory Card. You can restore the created backup by using the "Restore backup" option in the same Sync & backup Menu. It is also possible to restore the backup by directly opening the backup file which you have created in the Memory Card.
May 05, 2011 | Nokia X3 Cell Phone
Sir I tried to copy the pictures from camera to my PC but its not opening n show no folder in side the camera but when i take out the connection from PC it automatically showing the pics in cam.Will you...
Hi, the photos are visible in the Camera and not when connected to camera because in Windows the photos are hidden. You can view the hidden files by following below mentioned steps:
Please connect the Camera to the Computer, then open the Folder containing the Photos:
Click on Tools>Folder Options>View tab>select Show Hidden Files, Folders and Drives option.
Then, click OK. Now the photos should be visible in Windows.
Please reply me if you face any problem in following the above mentioned steps.
Apr 07, 2011 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Lost Leopard mail from iMa
I am afraid i gave in and found an Apple repair company. They sorted it out at a high cost but I cannot function with all my interests without a machine that I can trust. The engineer said he found my E mail in the waste bin. No idea how it got there or how I could recover it. I had look at the contents of this bin several times and never saw anything resembling mail.
Thanks for your concern folks,
John
Jul 18, 2009 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
CAn't view photos in media center xp. The photos
The photos will need to be imported into Media Center.
Let me know if you need instructions for importing.
Please rate this solution.
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Jul 08, 2009 | HP Pavilion dv8230us Notebook
Cannot access any of my backup files
go on ebay you will get one on there for about a fiver mate
Mar 08, 2017 | Epson P-5000 Digital Media Player
Can't open Photo Expolosion 3
when trying to open photo explosion, looks as if it is going to open then I get an error message Cannot reset background image this message is frozen on my desk top I then have to restart my computer
it worked ok before, but now I get this error
Jul 19, 2008 | Nova Development Photo Explosion Deluxe...
Unable to open backed-up files. Error code 10657
I got error code 10657 when I tried to open a file in Finder on the external drive that I had used for a Time Machine backup before I reformatted the hard drive of my MacBook. When I started Time Machine on the MacBook (with Leopard reinstalled) and went to the backup date that held the desired file, I was told that I needed to recreate the containing folder (or choose another location for the restore). I chose recreate the folder, and the restored file was available in the new folder without any further problem.
Apr 01, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
2,319 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Lee Hodgson
Lee Hodgson
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
