Question about Refrigerators
Fan runs constantly, freezer ice melting, bottom drawer in refrig
The refrigerator fan runs continuously, the freezer comaprtment beginning to defrost(ice in ice maker beginning to melt) refrigerator not cold, but vegetables frozen in bottom drawers
Amana model SCD22TBW
    Genius:
  • 1,142 Answers
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    Could it need charged. if its running all the time it may need more refrigerant. or get a new refrigerator
    Posted on Jun 25, 2009
    Freezer side not cold enough, similar temperature as Refrigerator side
    It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
    Nov 12, 2013 | Refrigerators
    Over a period of days the freezer gets warm then cold. Ice begins to melt then freezes together. Ice cream gets soft, then hard. I removed the panel in the back of the freezer. Unlike other defrost...
    The refrigerator is sticking in defrost mode...
    Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator Defrost Timer Problem
    Water Running in refrigerator from Freezer
    Refrigerator or Freezer not Cooling or Getting Cold
    heatman101
    Nov 20, 2010 | Amana Side-By-Side Refrigerator 26 cu. ft...
    Freezer light blinking Ice maker not making ice freezer not as cold
    sounds like ur freezer is in alarm due to not being cold enough and wont allow the ice maker to distribute water to be frozen into ice u should have a fan behind the back panel inside the freezer make sure it is working and the coil underneath it is not frozen solid if the fan isnt working then check and make sure it has power if it does and the fans not running then replace the fan and this should get ur freezer working again but if the coil is frozen and the fan is running then u may have a bad defrost element that runs through the coil it is black u can test it by taking the wires off it and checking continuity thru it if it has continuity then its ok if not then it needs replacing
    Mar 01, 2010 | Samsung RS2534 Side by Side Refrigerator
    GE refrigerator, ice melts in ice bin
    Since your refrig is cooling , I would replace the # 4 AND # 5 thermistors . The # 4 thermistor , tells the main control board , the temp of the coils , if they need defrosted , when they are thru defrosting . This thermistor is the 1 " long , torpedo looking piece , clipped on the top left of the coils , with 2 white wires going to it . Part number WR55X10025 . It would be advisable to also replace the # 5 thermistor , located at the bottom of the freezer , slightly in front of the drain , also with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , associated with the fan speed also .
    Nov 16, 2009 | GE Profile PSW26P Stainless Steel Side by...
    Our freezer is not cold, food is defrosting, ice is melting. Refrigerator is working, freezer is not. We hear compressor running continuously. This is a side by side Amana model with water & ice maker...
    Look at the back of the freezer wall from inside the freezer. Is there frost on it? If there is, you need to replace one of the components of the defrost system. If there is no frost then you need to have a repair made to the sealed system, it is either out of gas or the compressor is running inefficiently
    Jun 20, 2009 | Amana 22.6 cu. ft. Side-By-Side...
    Freezer cold but not fridge
    too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
    Aug 05, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
    Freezer not cold, the meat is melted
    Sounds like you have a defrost problem. Pull the back panel off inside of the freezer and make sure the fan is running (evaporator fan motor). If it is, check the defrost heater and defrost thermostat for continuity. If one is bad, you have found your problem. If both are good, replace the defrost timer, adaptive defrost board, or main control board (I'm not sure which you have since I don't have your model number). Let me know if I can be of further assistance.
    Mar 27, 2008 | Kenmore 53542 / 53544 Side by Side...
    Fan is Running
    Your refrigerator isn't defrosting. When you melted the ice on the coils in the freezer you might have noticed a glass tube with a wire going into each end this is your defrost element that is probably bad. If it tests out good then your problem is either in the defrost thermostat, or the motherboard that tells your fridge when to defrost.
    Nov 14, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
    Refrigerators Logo
    1,144 people viewed this question
    Top Refrigerators Experts
    John Tripp
    John Tripp
    Marvin
    Marvin
