Philips Magnavox 27MS343S 27" TV Logo
Question about Philips Magnavox 27MS343S 27" TV
Magnavox 27ms343s tv won't turn on manually or with remote, help
My tv just won't turn on. i thought i might have activated the child lock i have the code to deactivate but the tv won't turn on. can't locate the owners manual. please help if you can any solutions
Posted by mddrcc on
Herbert Metz
  • 102 Answers
If you are comfortable with tool sthere is a fuse inside the unit right where the plug goes in. I would check this first. Caution unplug it first VERY high voltage inside 30,000 volts!!!
Posted on Mar 24, 2009
Anonymous
    New Friend:
Posted on Feb 15, 2011
I have a magnavox TV mod. No27ms343s that does not have a remote. WS using spectrum remote to turn TV and box on and off. Someone set the child lock and now I can't turn TV on at all.. can u help?
You need a television remote. The Spectrum remote only does simple features. The Magnavox remote is available on Amazon and eBay.
https://www.google.com/search?q=magnavox+TV+27ms343s+replacement+remote
Try disconnecting the television from the mains supply overnight.
Megapower. how do I remove the child lock without a remote?
How to reset "Child lock" on TV without remote ' Electronics Forum ...
www.electro-tech-online.com > ... > Repairing Electronics
Apr 8, 2010 - 21 posts - ‎11 authors
I opened the TV, but no "switch" on the PCB to do a "reset to factory". ... You almost certainly need the remote, and also the service manual that .... and I was able to get into the menu by remote and to disable the Child lock.
How to disable child lock on Magnavox 27MS343S without remote - TV ...
www.tv-forums.com/.../How_to_disable_child_lock_on_Magnavox_27...
Sep 23, 2012 - 7 posts - ‎3 authors
Hello, I have accidentally turned on the child lock (not parental lock) on my Magnavox 27MS343S for which I do not have a remote. Since the ... panasonic television child lock
Apr 21, 2012
Apr 8, 2010
More results from www.tv-forums.com
Son lost remote for his tv and the child lock has come on how do i turn it off
THE SOLUTION FOR THIS FIX, AS IT WORKED FOR ME....I WAS LOCKED OUT BBY THE DUMB CHILD LOCK FOR TWO MONTHS, BOOUGHT A NEW REMOTE THAT DIDNT WORK....GET A 10$ REMOTE FROM THE STORE, AND ENTER CODE 0224 IT KILLS THE CHILD LOCK FEATURE..THEN YOU CAN POWER ON THE TV..GO TO MENU AND SELECT CHILD LOCK AND DEACTIVATE IT! THANKS ALOT MAGNAVOX..IT WAS NOT IN THE MANUAL FOR THE TV OR THE REMOTE FOR THE TV EITHER......CAPERS~
2helpful
I have a magnavox 27MS343S and it is child locked, tv is off and do not have the original remote! What can be done?
I have a magnavox 27MS343S and it is child locked, tv is off and do not have the original remote and it wont turn on although the powered up red lighht is on. Tv has been reset to sleep mode by universal remote. What can be done?
Locked tv
You need to buy a remote for that TV. They're available online for around $39. This site has them in stock, but you can shop around to be sure its a good price. When you receive it, turn on your TV and press menu on the remote and turn off child lock. Click the Remote here:
http://www.newremotecontrol.com/catalog/dyn_models_accys.php?modnum=27MS343S&hash=e91e6348157868de9dd8b25c81aebfb9
1helpful
My TV is in standby mode, with tge child lock on. How can I turn it on?
when you turn on child lock in magnavox models you deactivate keyboard on tv requiring original remote control to turn back on. remote control part number 996500015582 available through andrews electronics
1helpful
Child Lock issue
Unfortunately the Child Lock facility disables the buttons on the TV.
You should be able to get a replacement remote control from an authorised Philips dealer, or you could try a universal remote control form most electrical retailers. Philips make a range of universal remote controls.
Instructions for activating and de-activating the child lock are in the manual. If you don't have the manual, download it here:
https://www.p4c.philips.com/files/2/27ms343s/27ms343s_dfu_aen.pdf
2answers
Child lock
hi.... i did child lock my tv magnavox and can't turn on ,,,because my remote control is broke now.. so tell me please how could turn on my tv Please Tanks...
4helpful
2answers
Magnavox child lock tv
my remote control doesn't work, and i can turn the tv on because i lock to just use with the remote control. How can turn the tv on if i do not have a remote control?
Top Philips Televison & Video Experts
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
