Question about Canon Powershot SX110 IS Digital Camera 9.0MP
LCD screen not sharp / focusing when taking pictures
2 weeks ago, I purchased a Canon PowerShot SX110 9MP. When preparing to take pictures, images on the lcd screen are not sharp (i.e. noisy, grainy). When i review the pics in Playback mode they look sharp BUT when i print them out they are fairly noisy (even when shooting at ISO 200) and colors are not sharp / vivid at all.
I can play around with the ISO settings more, etc but my main question is RE: the LCD screen not focusing sharply when taking pictures, even when I wait for it to auto focus. Any advice is appreciated. Thank you.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
This camera is ancient by today's standards, at least 8 years old.
Your focus problem is that the back display is very low resolution, so it will never show a sharp image. 9MP should give a decent image when you view it on a computer. If not, you probably need to part with the camera. it is not worth much these days anyway.
Posted on May 01, 2017
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 623 Answers
SOURCE: my photos are coming out
When you use auto mode on most point and shoot digital cameras ( which includes the F717) the camera software gets to choose aperature, shutter speed, and ISO setting. When the ISO setting is used at the faster ISOs, the images get digital 'noisy' very quickly. There is a much higher noise level in consumer digicams at the higher ISOs, because the sensor chip is much smaller than in the digital SLRs. F2.0 suggests yoiu are shooting at the maximum aperature of your lens and that the light is pretty dim.
If you learn to use your camera in the Av ( aperature preferred) mode at ISOs of 50 or 100, most of the noise you are describing will disappear. The camera should take very nice images at ISOs less than 200.
Consult your manual on aperature preferred or manul setting of the ISO speed
Posted on Nov 20, 2008
kram26
Mark Milan silaran
  • 544 Answers
SOURCE: how to repair lcd screen canon powershot sx110-is
hi,
For that camera that died, here are some non-intrusive simple fixes that you should try before throwing in the towel. Copied this first post from somewhere. It was a fix for a Canon A520, but am not sure if it would work for other cameras with the same problem? For those of you with a camera that will not power up or turn on, especially if this occurred after a power interruption with your lens extended, please give it a try. If you do, please leave a comment on specifics like your camera make/model, and whether it worked for you or not.
"DEAD CAMERA, LENS OPEN-If the batteries run down completely while the camera is still open, it may not start up again when new batteries are installed. But if you remove the memory card, then install the new batteries, when you turn it on it should come back to life. Error E30 means you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time."
OK, so the above didn't work. Next thing to look at are the batteries themselves. Are you using alkaline batteries, or worse yet those "Super Heavy Duty" batteries? If so, betcha we've just discovered your problem. Alkaline and regular "super heavy duty" batteries just don't have the power for more than a few pics in a digital camera. Some may even have problems just powering startup of the camera. It doesn't matter if they're new, and right out of the package. Digital cameras for the most part should only be used with rechargeable NiMH batteries (if you still have your instruction manual, open it to the "batteries" section. Pretty sure you'll see a statement similar to what I've just said). Most retailers sell NiMH batteries for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
OK, so maybe those newfangled batteries didn't fix your camera, don't give up just yet. The next thing to check is that your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip.
The next thing to try is examine both the battery and flash card door. There's usually a little switch on both doors (note some SD card doors do not have this switch) that activates when the doors are closed. If they don't, the camera won't start to prevent damage to the flash card or camera startup sequence. For most cameras its usually a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be jury rigged with a small glued-on replacement.
If you've tried all of the above and still no luck, the problem is then likely to be internal to the camera. Am planning on posting sometime in the future some likely things to check, hopefully with a pictoral guide. One example would be that if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
As before, if one of these simple fixes worked in your particular case, please leave a comment on your camera's make, and which fix worked.
Good Luck!
Camera Repair please don't forget to rate our answers..
Posted on Feb 19, 2009
Anonymous
  • 47 Answers
http://digitalcamerarepair.googlepages.com
Posted on Mar 04, 2009
dennis bullard
  • 4090 Answers
SOURCE: grainy pictures...iso problem for olympus stylus 820
Without ISO you will not be able to take pictures.
ISO is the old ASA which is related to film speed
ISO 50 is very slow film speed and may result in blur and some grainy appearance , same as if you PUSHED ISO up to 800 in low light.
Try setting it to ISO 100 and see if that helps.
You can still select auto, but its related to either shutter or aperture priority in relation to the set film speed ( now ISO 100)
Posted on Sep 10, 2009
MY CANON G10 DOES NOT SHOW AN IMAGE ON THE SCREEN ON THE BACK OF THE CAMERA?
Known issue!
G10 => Dead Black Sceen ! (only on screen infos): Canon PowerShot ...
https://www.dpreview.com/forums/thread/2639340
  1. Cached
Aug 13, 2009 - 11 posts - ‎4 authors My G10 is dead a few days ago, in a middle of a trip... (can't explain my ... Does the camera take pictures and can you download them to your computer? Then your sensor is OK and ... No cover on lens, and tried every display mode, you can trust me. ... (and even on, I will not have a permanent black screen). PowerShots can't do purple!?: Canon PowerShot Talk Forum ... 29 Dec 2013 G11 Date & Time Issue: Canon PowerShot Talk Forum: Digital ... 31 Jan 2010 G10's LCD dims when held in vertical position: Canon PowerShot ... 16 Nov 2008 G10 Can we adjust in camera parameters like sharpness for JPG ... 16 Nov 2008 More results from www.dpreview.com
A Simple Fix for a Stuck Shutter 'Do It Yourself Digital Camera Repair
camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
  1. Cached
  2. Similar
May 30, 2009 - Would not recommend trying to open your cameras to repair this ... Also turn off the LCD screen (press the DISP or DISPLAY button). ... For many Canon cameras this will be shutter priority (Tv) mode (for .... I got the image back in about 5 tries. .... My Cannon S2 IS had a black picture and I fixed it from your ...
Canon G10 screen is black
www.lionebra.com/canon...g10_digital_camera/q1947687-canon_g10_screen_black
  1. Cached
Canon PowerShot G10 Digital Camera - Canon G10 screen is black- ... with the menu,changed something and now the screen does not show image of anything. ... has problem in CCD Imager and this part will be replaced to get back picture. ... E18 my canon powershot A150, got the whole E18 problem, it turns on with the ...
Canon Powershot G10 image quality problems... I have had my Canon ...
www.lionebra.com/canon...g10...camera/q4217842-canon_powershot_g10_image_q...
  1. Cached
Canon PowerShot G10 Digital Camera - Canon Powershot G10 image quality ... They are not coming back with a completely blank screen as I can see the ...
Digital camera repair - Digicamhelp
www.digicamhelp.com > Digital camera care > Digital camera repair
  1. Cached
  2. Similar
Digital camera repairs can be expensive if not covered under warranty or a service advisory. ... When a sensor goes bad, images may exhibit some or all of the following: ... Hard reset for Canon compact cameras: this has worked for some Canon ... a blank LCD screen, a stuck lens or sensor or other problem that can't be ...
S2 IS "black screen *****" problem: a SOLUTION! ' Canon PowerShot ...
https://www.flickr.com/groups/[email protected]/discuss/72157606903408401/
  1. Cached
  2. Similar
Aug 23, 2008 - My 1st Canon (film) camera was a TL and I'd probably still have it but ... The "change the batteries" problem: Does any S2IS *not* have the ... A couple of weeks ago i turned on my dear S2 IS and.. no image!! i could only see the menus .... Actually, I had to do it 3 times before the screen got back the image.
Nov 24, 2016 | Canon PowerShot G10 Digital Camera
My Canon SX210 IS is brand new. Just bought it on yesterday. The problem I'm having is that the LCD screen does not look sharp and clear when focusing on a subject. It looks grainy. Can you tell me if...
Some cameras display a grainy picture in low light. Do you have the camera set to the highest number of megapixels and fine image or do you have it set to a lower resolution to get more pictures on the card?
Dec 03, 2010 | Canon PowerShot SX210 IS Digital Camera
I have just purchased Canon Powershot A480
I think the "busy" part can be put down to the camera performing a function or recharging the flash. The red icon I THINK shows that the camera is focussing.
With the last model it worked so that you could half press the button to focus on something (eg a fast moving pet) and then once your pet stopped moving your could fully press the button to take a photo and the focus distance would remain the same.
Nov 27, 2009 | Canon PowerShot A480 Digital Camera
Canon PowerShot A60~~~Viewing screen black/fuzzy won't take pict.
Its known problem of ccd imager in Canon A60 camera and Canon will repair it free of cost.
Click Canon CCD Imager Advisory for details.
Jul 24, 2009 | Canon PowerShot A60 Digital Camera
Canon A60: Grainy pictures, jumpy lcd screen image
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jun 09, 2009 | Canon PowerShot A60 Digital Camera
Purplish hue to display image and picture on Powershot A75
Send to Canon, Theirs a recall on this model, Go to there web site look up service advisory, CCD malfunction. N/C
Feb 24, 2009 | Canon PowerShot A75 Digital Camera
The picture we have taken was white/grayish screen- no images..
I got it repaired at canon service center in India for Rs 1900.
Next camera I will insure !
Jan 19, 2009 | Canon PowerShot A460 Digital Camera
PowerShot S60: Purple Bar on LCD viewer Screen:
This sounds like it might be impending failure of the CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
Oct 17, 2008 | Canon PowerShot S60 Digital Camera
I cannot take clear pictures but everything else seems fine
Oct 24, 2007 | Canon PowerShot SD100 / IXUS II Digital...
Problem with image
What mode is the camera in? is it in "Auto" at the top there is a dial switch it to auto and press button halfway (shutter button) when you press the button halfway the camera will beep and display a square box on the LCD. If the camera beeps once and the box is orange it could not focus and you need to retry pressing halfway again. When it is in focus it will beep 2 times and it will show a GREEN box. This is the indication it could focus on the subject correctly. Its a machine and sometimes it takes it a bit for it to figure out what your wanting it to do. Its the nature of the unit
Apr 03, 2006 | Canon PowerShot A85 Digital Camera
Canon Powershot SX110 IS  Digital Camera 9.0MP Logo
175 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Ekse
Poul Brinchs Larsen
Are you a Canon Camera Expert? Answer questions, earn points and help others
