Turn on CD player Install Catridge works well flips through 6 CD real fast without playing. Dose not read or play, CD do not rotate to play.
SOURCE: Hello I have a Pioneer XC-L11
It is most likely that the laser pick up is bad. That is the part that reads the disc and is the most common reason. You can try a lens cleaning disc to see if it just needs to be cleaned, but if that does not work you will need to take it in for service. This problem can be caused by several different things, from the spindle motor (spins the disc), to the pick up (reads the disc), or even an IC that controls one of those things. Once you have cleaned the lens, you can also try cleaning the disc's. If a disc has a fingerprint or scratch in the area of the disc that is know as the TOC (table of contents), it will not read the disc. Fingerprints in other areas of the disc will cause the player to skip or even stop playing. I use windex and a soft cloth like a bath towel to clean the disc's, it works as good or better than the disc cleaning kits you can purchase, and it is much cheaper.
If none of this helps, it has a problem that only a trained technician can figure out with the proper test equipment. Then you must decide if it is worth getting fixed. Some service centers offer free estimates, but those are the ones that don't actually check your equipment first before giving an estimate. They just give you a ballpark figure that is usually pretty high. To get an acurate estimate you normally have to pay for it. A technicians time is worth money, my shop charges $25 for an estimate.That is pretty cheap. Some are as high as $65 for an estimate. But if you are paying for an estimate, they will normally at least troubleshoot the unit and determain just what the problem is, compared to a free estimate which is just a guess and a ballpark figure usually high to cover the cost no matter what the problem is. You may also end up paying much more for a repair when you get a free estimate, because you have already approved that amount, and many shops will charge you that much even if they find a simple problem that only takes 30 minutes to fix.
Replacing a pick up normally cost about $125 to $150 because the part can sometimes cost as much as $75.
I hope this was helpful for you and lets you make an informed decision. let me know if you need any more help.
Dave
SOURCE: 6 CD PLAYER FORD EXPLORER
usually these are not an economical repair, you either have a mechanical jam in the cd transport mechanism or you have a servo motor problem. you may be able to find a used working unit cheper then repairing you unit also when a repair is done on these changers they have a high repeat failure rate. If a local service center could just remove the jammed cd's and let it reset itself then try it again and see if it fails right away or works correctly, then you may have an idea on which way to procede
SOURCE: Kenwood DP-MH5 CD Player won't
CDs can be removed but you must use great caution not to break or bend mechanism components. Its better to have unit serviced by pro/tech
SOURCE: I have a stanton-vestax cd-11
Stanton-vestax CD33 I need universal cd player controller cable. 13 pins male to 13 pins male this is round conector.
SOURCE: re Hitachi AX-M80 - cD
This evening my daughter revealed she had the same problem. I wiped the eye with a tissue - now it works!
Some times the obvious is the answer.
